My new DLX
Hey everyone! Picked up my 2023 DLX today from TxPowerSports (as I’m local).
Did I get a counter-balanced engine?!
DFW HMCM(SW)[Ret] 2020 FLHTK 2023 EX400G Ninja 400 2023 Hawk DLX Last edited by BriNbigD; 11-09-2023 at 05:25 PM. |
It’s official
MotoCheez has confirmed the c/b engine! I was going back and forth over the X and DLX because of that c/b engine. Now I’ve got everything I wanted (except for the 6th gear…maybe I should go check that too!)
DFW HMCM(SW)[Ret] 2020 FLHTK 2023 EX400G Ninja 400 2023 Hawk DLX |
Awesome! I have a 2022 DLX.
2022 Hawk DLX EFI * 17T Front / 47T Rear / upgraded chain * Kenda K-760 front + rear * Banjo brake light switch * LED headlight + front turn signals * Debadged (I don't like to brag about the superior strength!) * Top speed, GPS verified, as equipped: 68 mph (so far) |
I don't think so. I think that's new for 23'. But, it's my 1st motorcycle experience so it's hard to miss what I've never had.
#6 | |
Speaking of upgrades check out my headlight inside and wiring bundle behind it! All LED and smooth!
#7 | |
You've got nothing but adventures and fun ahead of you on this bike! Post a photo now and then !
#8 | |
The LEDs are an upgrade from the 22 model. The previous owner of mine put in an LED headlight bulb. I changed out the front signals to an LED version. I'll do the back eventually, but haven't yet.
I have H4 LED ready to install but found the picture I posted when I pulled the headlight. No boot, not H4 connection. Already LED, I’m assuming…
Magnetic oil drain bolt
Unless TxPowerSports added this, I have a magnetic oil drain plug on the bike!
I upgraded the pegs with larger, better ones. Had to use the belt sander to hog off the right amount, but they are a great improvement.
Improvements
I’m pretty sure TPS didn’t touch the oil as what I just drained out is an abomination. I wouldn’t even call it oil. I don’t know where the Chinese get this stuff?!
I’ve also inspected all of the welds and they look REALLY good. No missed welds, etc. They’re not quite as good as on my Ninja 400, but WAY better than I could do—and more than acceptable. Even the passenger peg attachment points are welded as if someone gave a crap!
#12 | |
I think I have the same foot pegs. I also had to grind some material off. Loctite those studs on the pegs. I lost 2 in the 1st week before I pulled them all and added loctite
#13 | |
