Old 07-25-2023, 04:19 PM   #1
Sportbike83   Sportbike83 is offline
Sportbike83's Avatar
Templar X catalytic converter glowing on long idle.
Anyone else run in to this. I'm considering just punching it out. I've tried re jetting bothe the stock 28 and a PE30 all the way up to a 48 pilot. Still at a long stop light it will glow.
ID:	29770   Click image for larger version
Old 07-25-2023, 04:44 PM   #2
What RPM'S is it idling at? Should be around 1,500 rpms. A high idle will heat it up quick.
Old 07-25-2023, 05:18 PM   #3
When warmed it runs between 1500 and 2000. I'm more wondering now if during manufacturing this one was damaged a little and is to restrictive. It doesn't extend past it and nothing before it. Just that section of catalyst.
Old 07-25-2023, 05:27 PM   #4
Might be an intake air leak making it run lean.
Old 07-25-2023, 05:29 PM   #5
I think I have a can of Brake clean. I'll check that tonight
Old 07-26-2023, 06:57 AM   #6
Huck369   Huck369 is offline
Huck369's Avatar
Running lean will cause that for sure
Huck
2013 Honda NC700X
2013 Moto Guzzi V7 Stone
2016 AJP PR4
2022 Templar X 250
2021 Sondors Metacycle
AMA Life Member
Old 07-26-2023, 09:19 AM   #7
Generally speaking, running rich causes only the cat to glow. Lean would cause most of the head pipe to glow as well.
What's the difference? Lean exhaust is hot right out of the head. Rich exhaust is actually cooler. Why does the cat glow? Unburned hydrocarbons burn off at the cat, and if the engine has a PAIR system (air injection) it really ramps up that burn and makes it get very hot.
This was seen a lot in the mid 2000's on diesel trucks that had regen cycles for the cats. The computer on those trucks would ramp up the engine speed to spool the turbo, and do a double injector pulse to get more fuel into the exhaust to help burn off carbon by igniting raw fuel in the cat with a bunch of fresh air. The cats would glow red, and they sometimes got so hot they would melt the cab of the truck or the asphalt under them.
