Old 06-23-2023, 12:56 AM   #1
Jds1988   Jds1988 is offline
Doh! Brozz 250 broken clutch bolts
I am a new owner of a ‘22 Brozz recon and have been doing some upgrades. I just recently attempted to install some upgraded clutch springs and sheared off one of the bolts holding the springs in and I’m not sure how to go about fixing this. My question is should I replace the whole clutch basket or just the screws and where can I get the correct parts? If anyone can help it would be greatly appreciated.
Old 06-25-2023, 04:17 PM   #2
CheapThrills   CheapThrills is offline
I did the same with my TBR7, I pulled the whole basket out, and using a drill and small drill bit, was able to drill into the bolt, from the front(not the head side) and as the drill bit, well bit into the bolt, it screwed the bolt out.
Once out, I bought new bolts at like a Lowes.
I believe the bolts' torque is measured in-lbs, I just hand tighten them with lock-tite.
It's what I did, hope all goes well.
- My 2 Bikes:
TaoTao TBR7
Boom Vader Gen 2 (BD125-10)
Testing a YouTube Channel
Old 06-25-2023, 07:48 PM   #3
I’ll try that thank you sir
Old 06-26-2023, 12:24 PM   #4
108 inch lbs for most small Honda engine clutch bolts. Aka 9lb-ft
brozz 250, clutch assembly, clutch issues
