Old 06-15-2023, 01:28 PM   #1
JadenHamilton   JadenHamilton is offline
Doh! Dropped Intake Gasket into Engine on Vader
I dropped a little piece of the paperlike gasket down into the engine on my Vader gen 2, when trying to retune my carb. I tried fishing it out and couldn’t see anything, I tried turning it over after and it won’t start. I’m not smelling gas. Anyone know what to do?
Old 06-15-2023, 05:48 PM   #2
Bruces   Bruces is online now
Did you try spending the night at a Holiday Inn Express ?
It works on TV .
I am thinking you should probably pull the head and clean out the junk .
Old 06-16-2023, 08:28 AM   #3
4T_Goblin   4T_Goblin is offline
4T_Goblin's Avatar
Pull the head off if you think the gasket piece is around the piston.
Otherwise check your pilot circuit makes sure it's not clogged
2020 Vader X-Pro X-7
2019 Kawasaki Ninja ex400
2022 Lifan KPX 250
Old 06-16-2023, 08:54 AM   #4
Mudflap   Mudflap is offline
Chances are the gasket material got stuck under the intake valve. I'd try turning the crankshaft so the intake valve is open then blow compressed air into the intake to try and dislodge it.
125, boom vader, engine, issue, vader
