Old 03-06-2023, 03:06 PM   #1
98 SNAKE EATER   98 SNAKE EATER is offline
Question Identify used engine?
Some of you already know I've been trying to get the 167FMM in my CCW Heist running with no luck.
In the meantime I've also been searching for a replacement engine just in case.
Found one local on marketplace, but curious if it will be a direct bolt in or if there are any differences (all these things look to same to me lol).
I figure it might be worthwhile if I can get it on the cheap
ID:	28743   Click image for larger version
ID:	28744   Click image for larger version
ID:	28745   Click image for larger version
ID:	28746   Click image for larger version
Old 03-06-2023, 05:22 PM   #2
buzz   buzz is offline
How much,and is it a runner.C
Old 03-06-2023, 05:23 PM   #3
Check compression!
Old 03-06-2023, 05:28 PM   #4
Seller claims it came out of a running ATV, which already sounds shady (why pull it then?)
I'd definitely want to see it crank with my compression gauge before making an offer.
Old 03-06-2023, 06:07 PM   #5
Mudflap   Mudflap is offline
If it came out of an ATV then it likely has 4 forward gears and a reverse.
Old 03-06-2023, 06:27 PM   #6
XLsior   XLsior is offline
XLsior's Avatar
as Mudflap suggested, if its from an ATV it likely has a reverse gear.
looks to be a 250cc.
Has Zongshen branding on the case covers, but the engine serial number does not begin with ZS...
ok for parts or an ATV/gokart transplant.
