Old 03-05-2023, 08:51 PM   #1
Jakkson614   Jakkson614 is offline
Lifan Xpect
I have a buddy working on my bike we took it apart and valve failure. He said buy an entire valve assembly. I’m a hard time deciding on which one to buy. I don’t want to get the wrong part any suggestions.
Is this one ok?
https://www.ebay.com/itm/13380231394...BoCU44QAvD_BwE
Old 03-05-2023, 09:50 PM   #2
XLsior   XLsior is offline
XLsior's Avatar
if its a push rod CG engine then that head should be fine.
Old 03-05-2023, 09:53 PM   #3
Ok I’m new to this and I didn’t want to buy anything before I made sure
Old 03-05-2023, 09:56 PM   #4
XLsior's Avatar
what is wrong with the old head, bent valve?
you might want to inspect the push rods if that's the case.
Old 03-05-2023, 10:00 PM   #5
He checked everything out and just told me I need a replacement head. There is a language barrier between us but guy knows his stuff
Old 03-05-2023, 10:01 PM   #6
XLsior's Avatar
a 250 head would work too...
using your ebay link page...
https://www.ebay.com/itm/12543481117...item1d347f5322
Old 03-05-2023, 10:06 PM   #7
Ok man I’ll order it. Thank you for the info. I didn’t know a 250 would work. That’s crazy
Old 03-05-2023, 10:09 PM   #8
What about the head temp sensor?
Old 03-05-2023, 10:19 PM   #9
XLsior's Avatar
Is your bike EFI?
Not personally familiar with EFI systems.
that might complicate things...
Old 03-05-2023, 10:21 PM   #10
Yes EFI
Old 03-05-2023, 10:31 PM   #11
XLsior's Avatar
i'm not sure how integral the head temp sensor is to the EFI operation.
Both heads will fit...
The C200 head should not alter factory specs like compression/valve clearance/pushrod length.
The Cg250 head will bolt on to a cg200 cylinder...but im not making any guarantees...
I can't find any EFI heads. I don't know where the temp sensor is located...
Sorry that's as far as I can help...
Old 03-06-2023, 08:15 AM   #12
You can drill and tap the head for the temp sensor in a couple of spots. the underside of the top motor mount flange seems to be a good place to do so.
Old 03-06-2023, 08:45 AM   #13
So which head should I purchase then? The CG250 head even tho I have a 200cc ??
Old 03-06-2023, 03:36 PM   #14
Boatguy   Boatguy is offline
Boatguy's Avatar
Also, don’t forget to try these guys. They know what they are talking about. It’s a little better than ordering without the information. They can probably get you the actual head that you need. The factory part.
https://kpclubusa.com/collections/x-pect
2020 Lifan x-pect
Old 03-07-2023, 05:46 AM   #15
Thevines2   Thevines2 is offline
I been doing a ton of research on lifan bikes, this seems to be a common issues if the valves are not adjusted shortly after getting the bike with most these China bikes. I'm back n forth between xpect kpx250,kpm200 turned into scrambler/enduro(tires, brush guard or skid plate, handlebars?, handguards,etc) really can't find too many reasons to not go with lifan for the price. But yeah the valves seem to come too tight stock and causes them to wear out and break prematurely
lifan 200 parts, xpect
