Old 12-30-2022, 11:24 PM   #1
boomrider   boomrider is offline
Boom Vader emissions question
I could not get my plastics off because of an awkwardly placed screw underneath the seat that couldn't be removed. I wanted to remove emissions though, so at the information of a youtube video I watched, the fella said to wiggle the charcoal canister and pull it out. Wiggling was an understatement, but I eventually snatched it out. Is there anything that I need to connect/disconnect after doing this? I left everything as-is after pulling the emissions off so I don't know if I need to connect the hoses that came off somewhere. Thanks so much.
Hunt
Old 12-31-2022, 01:52 PM   #2
Deckard_Cain   Deckard_Cain is offline
Any lines that were previously connected to something, need to be blocked off or plugged.
If you can post up some pictures of what you have now.. I can tell you what to do. I removed the emissions on my vader so I know what goes where and whatnot.
You'll have the exhaust recirculation tube that will need to be capped off or a block off plate installed as well.
Old 12-31-2022, 06:59 PM   #3
CheapThrills   CheapThrills is offline
A lot of the 'emissions' items fell off while doing my carb upgrade. I plugged the exhaust tubing with some epoxy putty.
https://mymotorcycleblog.com/boom-va...cc-grom-clone/
HTH,
- My 3 Bikes:
1. TaoTao TBR7 (My TBR7 Upgrades)
2. Boom Vader (FYI: My Boom Vader Upgrades)
3. 1978 Suzuki SG750
Testing a YouTube Channel
Old 01-01-2023, 12:17 PM   #4
4T_Goblin   4T_Goblin is offline
4T_Goblin's Avatar
Get an EGR block off plate and you'll be OK. Plug the air inlet on your stock manifold.
2020 Vader X-Pro X-7
2019 Kawasaki Ninja ex400
2022 Lifan KPX 250
bom, boom vader, emissions, vader
