Old 11-03-2022, 07:33 PM   #1
Thedude4355   Thedude4355 is offline
2005? Pantera 125
So, this old bike was sitting behind a neighbors barn under a tarp. I've cleaned it up, and I can fire it up, but as soon as it starts it throws oil out of a vent on top of the crank case, under the carb. I'm sure it's supposed to be a vent, but I'm not sure if it requires a valve? Like a PCV valve on a car? Or is it just meant to have a hose on it? The rubber hose that was on it was rotted off and isn't anywhere to be found.
Old 11-03-2022, 09:30 PM   #2
Overfilling could cause this
Drain the oil (overnight!). Replace with 900 to 1000 mL of a good clutch friendly oil. Then try again.
Old 11-03-2022, 11:16 PM   #3
dirtbkr188's Avatar
...And run the (missing) crankcase breather hose down the back of the engine between the frame and the swingarm
Old 11-05-2022, 10:13 AM   #4
alex_in_az   alex_in_az is offline
I had one of those, bought it from PEP boys for $999. I ended up putting a 200cc engine in it and turning it into a cafe racer
2020 Tao TBR7
9.3:1 PnP head
CRF230F exhaust
4 degree advance key
290 degree cam
Nibbi PE30 and cone filter
Front fork brace
Old 11-05-2022, 03:54 PM   #5
I remember your build thread. Somewhere here on Chinariders
125, pantera
