08-24-2022, 08:45 AM | #1 |
Apollo Rx250 Electric problem !
Hello everyone !
I'm new here and i want to ask you something about my Apollo Rx250 db-36c 2020. What type of CDI it use DC or AC? I burned up 5 CDI's. Ok first time i had a stator and voltage regulator problem, i changed them, i checked all wiring system but last time when i connected a new CDI guess what? I burned it. Help please i think i'm starting to go crazy. Thank you |
08-24-2022, 08:47 AM | #2 |
Oh, btw motorcycle start with my old CDI but die when i hit throttle.
08-24-2022, 08:54 AM | #3 |
Easy way to check what cdi you have is test the connector with a multi meter. DC is powered from the battery when not running. AC gets power from the Stator while running.
08-24-2022, 10:20 AM | #5 |
Yes.
08-24-2022, 10:48 AM | #6 |
Stators on 70s, 80s Suzuki GS series were AC, three wire. But they went through the rectifier where there is a diode to convert to DC. I thought this might be how these bikes are set up if they have a stator. Oh, and rectifier/regulator was one unit as I recall.
So your post #3 above Jerry (DC setup on the right) applies for this type of system, powering the CDI with 12v. ?? |
08-24-2022, 11:08 AM | #7 |
I didn't tried yet what Jerry said. But here is a picture with my wire plug for CDI. https://postimg.cc/5XSfw3XY
08-24-2022, 11:21 AM | #8 | |
08-24-2022, 03:08 PM | #9 |
Yes ! I've seen this wire configuration on youtube, but i already tried a DC CDI and i burned it, ok, this was when i had shortage on stator, i will buy a DC CDI and i hope it will work, but i really tired to spend money on CDI's and motorcycle burns them when i press button.
08-24-2022, 04:11 PM | #10 | |
apollo 250 rx, cdi, db-36c |
