Old 06-18-2022, 03:41 PM   #1
Boatguy   Boatguy is offline
Boatguy's Avatar
Why won’t this fn tire go on?? Lolol
What did I tell you? I’m stuck. I can’t get the last bead of the tire to go on.
I know what has to be done. I think. The rest of the bead on the other side of the wheel has to go down into the groove where the spokes are. That will give me enough slack to get it over the rim. But I don’t know how to get it to go down into the groove! What do you do?
I am stuck right here. It will not go over the rim. The tire is smaller than the rim. At least it is smaller than the rim in a normal finished position.
2020 Lifan x-pect
Old 06-18-2022, 03:50 PM   #2
XLsior   XLsior is offline
XLsior's Avatar
maybe leave it the sun to warm up for 10 min and then give it the Popeye spinach treatment.
Old 06-18-2022, 03:51 PM   #3
Boatguy's Avatar
False alarm! The secret is to just take a little tiny bites out of it. 1 inch, stand on the other side while you are doing it, another inch, another inch, and all of a sudden pop! It goes on.
2020 Lifan x-pect
Old 06-18-2022, 04:10 PM   #4
Boatguy's Avatar
After all that it’s leaking. And it takes a loooong time to get a new tube. I have the heavy crappy one still but would rather put the Michelin in.
2020 Lifan x-pect
Old 06-18-2022, 04:24 PM   #5
CaptainCanuck   CaptainCanuck is offline
CaptainCanuck's Avatar
Not sure if you are using any lube on the beads, looks kind of dry in the picture. Some soapy water on the beads makes the tire a lot more manageable as the lube lets the tire slip around versus getting hung up on the bead dry. It also makes it easier to keep the majority of the tire in the deeper part of the rim to give you more slack to work with.
Old 06-18-2022, 05:33 PM   #6
Boatguy's Avatar
Well, now I have the el cheapo tube in the rear. IRC brand off Amazon. Heavy and thick. Shiny rubber. Yuck.
Getting the back wheel back in is insanely difficult. I had 4 parts trying to fall off while trying to thread the axle through them. And fall they did. A lot. Wow.
On to the front sprocket and chain now.
4000 mile (late) maintenance almost done.
Just need to do chain and front sprocket as well as front tire/tube. Brush guards/hand guards didn’t fit. Ugh
2020 Lifan x-pect
Old 06-18-2022, 05:37 PM   #7
Boatguy's Avatar
Did it all back road development style too.
Greased everything. Bearings, axle, tire. Oops! Yup. A ton of grease on my tire. Gotta soap and water that off before riding.
2020 Lifan x-pect
Old 06-18-2022, 05:41 PM   #8
Boatguy's Avatar
It’s true. It’s dry. I didn’t even use any tire juice. It went right on anyway. I didn’t need that stuff.
It was more of a false alarm on that part of things. But I did definitely wreck my good Michelin tube.
Megadan called that one.
2020 Lifan x-pect
Old 06-21-2022, 03:48 PM   #9
Sochin   Sochin is offline
Sochin's Avatar
What if?
1983 Honda Xl600R
2016 Ducati Multistrada 1200S DVT
Old 06-21-2022, 04:19 PM   #10
Boatguy's Avatar
Oh no!!!!!!
As I was wrestling this thing on that was crossing my mind a few times. Lol
Originally Posted by Sochin View Post
2020 Lifan x-pect
