TT250 any clue to this :
#2 | |
Nothing. It's a vent. The business end of the canister are the two hoses on the top.
Hello nothing to worry about,same as mine a TBR7
Yep that's just the canister vent, it's only there because of strict CA emissions.
This may or may not pertain to you, but I had to swap the two hoses that are going into the canister because many of the 2021's accidentally had these reversed. It causes a vacuum in the gas tank, which can be seen the most when you fill up the tank (the bike will die after a short time running), and another telltale sign I learned here is that you'll hear a whoosh of air when you pop the gas cap. It will also start back up if it dies when you do open the gas cap. |
