2020 hawk deluxe
Runs good but sometimes when cold it hesitates and when it’s warm sitting at a idle and when I hit the throttle it cuts off , I did valves did not solve the problem, might do them again
Any ideas what could be causing this, I thought efi would solve the hesitations and stalling issues
How many miles do you have on it? Mine kinda does the same thing and only 20 miles.
It might takes some miles for the ECU to learn. Give it some time.
100 miles
I tightened back wheel to 69 foot lb and wheel seems to have drag on it does yours have drag
Hi, no just checked this morning. My torque on the bolt is 65 and I don't think 69 would make a drag. How's your chain tension?
Chain is good ,,,from what I saw it is supposed to be 68.59 I rounded to 69 foot lbs
My manual says torque 65 ft lbs on rear axle 45 on front.
You are right I
Got the information from this forum but it really didn’t make a difference |
