05-25-2021, 08:06 AM | #1 |
Tbr7 needs a Tach
Well maybe needs is a bit much, I guess more i would like to add one to the bike. Does anyone have a simple add on Tach or something that they can recommend?
Thanks in advance. |
05-25-2021, 08:32 AM | #2 |
The little digital tach/hour meters work well and are super cheap and easy to install. The disadvantage is that they have a small display and aren't quick to update.
05-25-2021, 08:11 PM | #4 |
Digital Tach
It took a bunch of wiring work but I installed this digital instrument cluster. I am really happy with it and can offer guidance on how to install one. I even have a template to create the mounting bracket.
You can also see the phone charger/voltmeter/temperature and tire pressure gauge in the photo. For $110 I got the same digital data as a KTM or BMW provides. These photos were taken during the install the final is very buttoned up. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Last edited by dhilbish; 05-25-2021 at 08:49 PM. |
05-26-2021, 12:24 AM | #5 |
Right on thank you guys!
05-26-2021, 04:41 AM | #6 | |
Do you think that cluster will fit behind the stock headlight plastic? |
05-26-2021, 05:50 AM | #7 |
It does fit behind the stock headlight. I will grab a photo of mine. It is tight but actually looks pretty good.
05-27-2021, 12:18 AM | #8 | |
Ok cool thank you for the help and info. |
06-03-2021, 10:10 AM | #9 |
Final Digital Cluster
Here are the photos of my final installation of a new digital cluster. I managed the digital cluster, a tire pressure sensor, voltmeter and USB charger for $110.
I am setting the bike up for a long distance ride in Africa. |
06-03-2021, 10:51 AM | #10 |
that's an awesone setup you've got there! where did you get the wind shield from? also how is the tire pressure display mounted?
06-03-2021, 01:24 PM | #12 |
i am wondering if you can set your odometer with this dash? i am looking to replace a failing Trailtech vector, and in NY i need to have accurate odometer for inspection....
06-03-2021, 08:44 PM | #13 |
The windshield is from Amazon. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1.
The tire pressure guage is mounted with a simple bolt on the custom bracket I had to make for the Tach/Spedo https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
06-03-2021, 08:56 PM | #14 |
The odometer is configurable.
06-03-2021, 08:56 PM | #15 |
I have a cool guage from Matt for sale if anyone wants ones.
