Zs250gs engine tuning
Hello guys. This is my beast , an old 2006 Zongshen ZS250GS converted to Cafè Racer. Engine is ZS172FMM. I want to give the engine some bit of power, because now is a slug.
https://ibb.co/HYkhnJH https://ibb.co/3cCRmfd Can you give me an advice please? What carburetor can I use? PWK 34? How much can I raise the compression with pump fuel? What kind of CDI and ingnition parts can i use to improve performance? Is there any performance camshaft that I can use into my ZS172FMM engine? Thanks |
Welcome aboard! Biggest carb i would go with is a PWK30 if you are porting the head. I'm bumped my X22R up to 11:1 on pump gas and the PWK30 was perfect. I've gotten good results with advancing the timing with a 4 degree offset woodruff key. I'm not very familiar with the ZS172FMM so not sure what cams will work with your engine.
I think it's a copy of a Yamaha XT225/TW200 motor, but I would need to see a picture of the left side of the engine. If so: https://www.tw-parts.com/
