12-22-2020, 08:42 AM | #106 |
My mom turn 95 yesterday. She get around better than I do. lol
12-23-2020, 11:22 AM | #107 |
Headlight and taillight wiring is done.
Still have brake, signals, and probably a neutral safety switch to do. No pic of the headlight cuz it's blinding.
12-23-2020, 11:24 AM | #108 |
Looks good! If someone rear ends you with that bright tail light they are totally blind. lol
12-24-2020, 01:55 PM | #109 |
I now have working brake lights. Halfway through the turn signals. That's causing some head banging because I had to rewire the innards of the headlight bucket. Damn 24ga wires.
12-24-2020, 04:44 PM | #110 |
We now have working lights all around. Couple of videos without my lilting Midwest twang but with Christmas music.
All Working by Mike Bullis, on Flickr Front Works by Mike Bullis, on Flickr Sorry about the jiggling but my arms only stretch so far. Merry Christmas folks.
12-27-2020, 05:37 PM | #111 |
Cleaned up and loomed the wiring this afternoon. Almost looks professional. Almost. About all that's left that I can do without the tubes is figuring out where to mount the starter switch, mount the speedo, and rebuild the front caliper.
01-09-2021, 05:12 PM | #112 |
When I showed the Diesel Project to the grandsons last week, I found the left front turn signal not working. Looked into it this morning and found one of the pins in the plug out of place. All better and I made sure the pin clicked in place this time. For grins, I checked the total amp draw of the lights. With the tail lights, headlight on high beam, brake on, and the right turn signals flashing, the draw was a paltry 0.82 amps. I will take that any day.
It also turns out that I now have a couple of helpers. Both the boys didn't know grandpa could do magic with electricity or glue two pieces of metal together with fire. Or actually work on motorcycles. They just thought I rode them. I'm figuring their help will only push the project back a few more months.
02-21-2021, 01:40 PM | #113 |
So, something happened with the Diesel Project today. I got the tubing bender mounted to the bench and bent metal.
First attempt with 15 x 2 hydraulic tube. Took a bit o' grunt but it came out pretty decent. Okay, so I bent a tube. In my employers eyes, I saw it and did one, therefore I can now build Saturn 5 rockets(dating myself and I ain't BSing about GNA). Time to try some 1" x 1/16" steel tubing for the frame. I set everything up, double check my measurements because, even though this is Outhouse Engineering and Fabrication where our motto is "Measure Once And Hope For The Best", that tubing is not some of Menards' finest Chinese 1010 hot rolled. It cost real money. Back on task...I grab the handle and pull. The 1" tube just laughs at me. I change my position and get behind to push the handle. EERRGGHHH! Nothing. Try again. MJ comes on the radio just after Madonna. Gahh! I don't want to hear this. EERRRGGHHH! Nothing. Catch my breath and search for something to use for a 'torque enhancer' because 'cheater bars' are mucho illegal on the railroad. I cobble together enough 'TE' material to get a 6.5' extension and commence to push and pull and grunt and groan and pant. Yay? It's bending. It takes a good 5 minutes of starting and stopping, but I get my bend. I check it against the frame. Perfect. Now comes the hard part. Making the second one exactly the same as the first one. Not always easy. Get set up and start bending. Good lord, this is hard work and I'm already pooped. Darkness gathers at the edge of my vision and my breath comes in ragged gasps. Blood is pounding in ears. ELO comes over the Zenith. At least I think it's ELO, too noisy in my head to be sure. Better than the other crap the local AM classic station subjected me to(Also known to play, gasp, Disco). Got this one bent, too, but it took almost 10 minutes and I had to sit down for a breather. Lo, and behold, the second tube is a perfect match to the first. Fist bumps and toasts all around. If I ever consider modifying another MC frame and it requires the use of 1" tube, I'm springing for a hydraulic tube bender.
02-21-2021, 07:42 PM | #114 |
02-21-2021, 08:48 PM | #115 |
I've seen that bender on Amazon for around $150. In your opinion, would it be able to bend conduit without pinching it? And if so, what's the smallest die you could go to for 3/4"?
02-21-2021, 09:55 PM | #116 | |
$115 on fleabay. Handles 3/8"-10mm to 1"-25mm.
02-22-2021, 12:01 AM | #117 |
I completely forgot that there are different sized dies. Thanks.
03-01-2021, 08:35 AM | #118 |
Looks like it's time for Plan A v2.0, followed by Plan B. Possibly followed by Plan C. No matter how I look at it, I can't cram ten pounds of crap into a five pound bag without stretching the entire frame 4". I didn't take the starter motor into account when I went over the Lambordini dimensional chart. Right now, the engine is halfway into the front tire. That ain't gonna work.
Plan A v2.0 is a maybe. I MAY be able to rotate the starter 180* if it is like many small engine starters that don't have a nose. I'd gain a couple of inches with the solenoid going up instead of down. Then I'd need to do more hacking on the transmission case, probably losing the transmission oil pump in the process. Plan A, v1.0 and v2.0 just may end up in the 'Experience Pile'. Plan B would consist of rotating the engine 180* and fitting a Comet 30 Torque Converter. Cheap and fairly easy to do, though I'd need to get creative from the jack shaft to the rear wheel because of the Suzukis' chain size. Plan C would consist of slicing open a vein for an HD tranny and clutch. More compact than the Suzuki transmission but 4, 5, and 6 speeds lack an overdrive. Did I mention that they are expensive? It always seems that it is a good idea, but...
03-01-2021, 09:14 PM | #120 | |
