Old 08-25-2020, 04:20 AM   #1
Cooperdevi   Cooperdevi is offline
Lowering Hawk
On the Amazon page for the Hawk, the description recommends the bike for riders over 5'8". I am shorter (5'4"-5'5"ish) and am wondering if there is an easy way to lower the bike to a comfortable height for me (I'd like to be able to flat foot it since I'm a new rider). Perhaps an adjustable spring, or shaving seat foam, or just a certain part I should buy?
Old 08-25-2020, 07:26 AM   #2
OneLeggedRider's Avatar
So you're 5'4", how much do you weigh? The reason I ask is you can buy a shorter monoshock for about $80. If you're a heavy person you're not gonna want to go any shorter than 290mm which will drop the rear 3". But if you're a lighter person you could go as short as 280mm which would be a 4" drop. That combined with dropping the forks 2" in the triple tree should put you close to flat footing it. Also CSC sells a lower profile seat for it.
~ Don't poke the bear ~
M.M.I. Dean's List graduate class of '95 and Specialty welder
2020 Ice Bear Terifecta 150cc Trike
2011 Honda Foreman 500ES 4x4
2001 Polaris Scrambler 400
Old 08-26-2020, 02:54 AM   #3
I'm about 130, so pretty light. Could you possibly send me a link to a good mono shock?
Edit: and possibly a link to the seat; I can't seem to find it. Thanks!
Old 08-26-2020, 09:45 PM   #4
Your height doesnt matter as much as inseam.
You can lower the rear about 3 inches without needing to then also shorten the kickstand. That will put the seat height around 31 to 32ish inches.
Seat https://store.cscmotorcycles.com/TT2...sc-300ttkt.htm
Old 08-27-2020, 04:23 AM   #5
Inseam is 30". Are you saying I can lower it without any new parts to 31-32", or would that be with a new monoshock? And would that plus a lowered seat probably be low enough?
Old 08-27-2020, 06:52 AM   #6
ss27gogeta   ss27gogeta is offline
That's going to depend on your inseam I'm 5'6 with a 29 or 30 inch inseam can't remember. but my xpect has a 32 inch seat hight and if I really stretch I can almost get both feet on the ground usaly I just put one foot down. or if both are down usaly the ball of both feet are touching.
Current Bikes
2019 Lifan Xpect
2016 Harley Davidson Roadster
Old 08-27-2020, 07:53 PM   #7
That would be with a 20 to 25mm shorter rear shock.
Old 08-27-2020, 08:50 PM   #8
Also, do I need anything to drop the forks?
Old 08-27-2020, 11:06 PM   #9
Baby Huey   Baby Huey is offline
Seat
That seat is in the accessories and it's kind of pricey!
Old 08-28-2020, 01:41 AM   #10
Yeah...where would I find a monoshock?
hawk, lower, rps
