TT250 Keima Carb Numbers
I wanted to know what the dimensions on the stock TT250 Keima carb were in case I want to replace it. After measuring it, I believe these bikes come with such small carbs as a pollution measure. Smaller carbs run higher vacuum and carburate more cleanly. The numbers I was able to glean:
carb to manifold stud holes: 48mm center to center (no surprise here) carb exit to manifold ID: 29.5mm manifold intake ID: 30mm carb intake OD (snorkle i'face): 42mm Venturi: 21mm by 28mm It is the last number I find most distressing. An Aermacchi 250. An Italiam 250 pushrod single from the 60's had a 28mm round bore carb stock. I find it hard to believe that a stock 229cc CG motor could not have decent drivability and a better top end with nothing less than a 28mm smooth round bore carb. Right now the only carbs I see out there that look promising are the PWKs that all have the power jet attachment. Does anyone know if they are round bore or oval bore?
4 time WERA SuperVintage Roadracing National Champion, SCTA Land Speed Record Holder, 3rd AMA Motorcycle GP of Miami Last edited by mtiberio; 06-17-2020 at 10:30 AM. |
#2 | |
#3 | |
Also i found the PE28 much easier to jet than the PWK. |
PE28 is an oval bore? Max venturi width, what? 26? With a choke plate to eff up the flow? No thanks
The PE is a round smooth bore just like the PWK. The difference is the PWK has a flat slide and the PE has a round slide.
#6 | |
The ones with a choke plate are the PD and the PZ(clones of the PD) The PE are mostly a PWK but with a round slide and no power jet. Plus you have the PE30 with has a bigger venturi. |
Good stuff, thanks. I ran PWKs on my Guzzi, so i'm familiar. The powerjet can always be defeated.
Yes of course that the powerjet can be disable.
I love PWK, so i tested them on various CGs (125 to 229), i like them a lot they performance great from 1/4 to WOT but they always seems to struggle at idle, no matter what pilot jet i use. So i did got a PE, they idle just fine but yes the PWK fells much better at near wot. |
