01-24-2020, 11:47 AM | #2 |
Welcome! I suspect your bike has a Honda clone CG200 engine from the mid-2000's. If so, there is a ton of good info on this forum. What do you need to know?
01-24-2020, 12:14 PM | #3 |
thank you i appreciate the help . All i want is all the useful threads for it ?
Can you please help !!!
SkyGo SG200GY-4 |
01-27-2020, 11:43 AM | #4 |
Search for CG200 and you'll have hours worth of reading on this forum.
01-27-2020, 10:05 PM | #5 |
Thanks Bro you’re really helpful ....
SkyGo SG200GY-4 |
10-08-2020, 08:33 PM | #6 |
skygo
I wanted to know at what rpm does your motorcycle idle. Does your bike vibrate a lot when you start up.
10-09-2020, 07:43 AM | #7 |
Idle should be set around 1500 rpm's.
10-10-2020, 04:04 PM | #8 |
do you know where i can find a manual for it? and how to adjust the clutch
02-20-2021, 10:53 AM | #9 |
yes bro, Vibrates a little when its cold on starting up . i have the manual sent you're Email bro
SkyGo SG200GY-4 Last edited by Viano SG200GY-4; 02-22-2021 at 03:54 PM. |
