Go Back   ChinaRiders Forums > General > News, Support, & Feedback
Old 10-16-2019, 01:12 PM   #1
L00N   L00N is offline
Engine ID 1p53fmi
Hello fellow riders!
Picked up an unbranded lifan hoping to swap it into a Honda SL90. Just arrived this morning poorly packed. Stamped on the case it says 1P53FMI and below it says 19040235. The sticker on top shows the shifter pattern as R>N>1>2>3.
I purchased it thinking it is a manual 4 up. These are the specs from the listinging:
Descriptions:
Max Power: 6.5 kW/7500r/min±375r/min
Rated Power: 5.6 kW/7500r/min±375r/min
Max Torque: 8.0 Nm/5000r/min±250r/min
Idle Speed: 1500r/min
Min Fuel Consumption: ≤370g/kw.h
Ignition System: CDI
Start Mode: Kick-starter
Spark Plug: A7TC
Clutch: Wet multi-plate
Transmission:4-speed, Manual clutch,4 Up
Carburetor Type: PZ16J
Primary Reduction Ratio:3.722
Gear Ratio:2.833/1.706/1.238/0.958
Old 10-16-2019, 01:27 PM   #2
duck9191   duck9191 is offline
Should be able to roll the engine over and verify if the sticker is correct, if it is then it was built to be an atv engine.
2020 Triumph Tiger 900 rally.
2018 Bashan Storm 250. pz30b, digital cluster + gear indicator, unifilter and car customs full exhaust.
2019 Taotao 110b boulder atv. The "arm breaker" lol
2007 Honda VTX 1300R.
1974 Suzuki tm125, work in progress
2001 Suzuki Drz 400s.
Old 10-16-2019, 01:31 PM   #3
The engine number won't give you any information on whether its a 4 speed or 3 speed with reverse. Looks like they sent you an ATV engine instead of a motorcycle engine. Might be the wrong shift pattern tag if your lucky. Try removing the plug and manually turn the engine to see if it reverses.
Old 10-16-2019, 01:32 PM   #4
We must of been typing at the same time. lol I like your shorter version. lol
Old 10-16-2019, 02:50 PM   #5
Took the spark plug out and put the shift lever all the way down, cranking the stator cover counter clock wise the sprocket spins ccw too. So I think I am in the clear, though the engine is not nuetral>1>2>3>4 as I wanted.
While I was shifting through the gears, the selector is now stuck in 4th. I cant seem to free it out of gear. Any ideas? Thanks for the quick replys so far!
Old 10-16-2019, 03:20 PM   #6
Try rotating the crank as you try to shift, might not be easy without it mounted but fresh gears don't always shift easy.
Old 10-16-2019, 03:55 PM   #7
alright. might just have to mount this bad boy up and get ripping!
Old 10-16-2019, 03:58 PM   #8
Please start a thread and keep us updated on the swap. We like lots of pictures.
