Bashan BSR Fender Eliminator
Decided to remove stock fender since it was bouncing and hitting the tire and save some weight. The install wasn't bad drilled a hole into the cross member, added washers and steel strap. I connected the bullet connectors with this kit I bought on Amazon.
This fender is very cheap so I took the LED housing apart and applied silicon seal internally for weather proofing. After the license plate is mounted, the fender only lasted 1/2 of a ride. ![]()
BaShan BSR 250 DB-41H 2018 Red BS250GY-18D JFG Racing Exhaust . Adjustable Shock 320mm . Brozz Digital Gauge . Renthal Fat Bar . 428 17x46 Sprocket . Fender Eliminator . Wheel Truing . Fuel Tank Repair . Keihin PZ30 Main-115 Pilot-38 Needle-1Washer Fuel Mixture-1/2 BSR Chronicles - "Project leads to more projects!" Yamaha WR250R Suzuki GSX-R 600 |
Thanks for the heads up. Too bad it turned out to be junk. It did look nice.
