05-22-2019, 02:48 PM | #1 |
chain tensioner bolt?
hello, i dont know how it happened but i crossed threaded the bolt that you adjust chain tension... where can i get a replacement?
To light a candle, is to cast a shadow.. |
05-22-2019, 02:54 PM | #2 |
I'm assuming this is for your Hawk? The CSC TT250 uses the same adjusters. https://store.cscmotorcycles.com/TT2...p/zt26-107.htm
05-22-2019, 06:06 PM | #3 |
The CSC adjusters are black, so if you care about matching make sure to order two. If not, one works.
