04-23-2019, 08:07 AM | #1 |
hawk 17t front 50t rear
So i just pt on my 17t front sprocket on my hawk. It has stock chain & stock 50t rear sprocket. I dont know how tight yall chain are with this set up, but mine is way too tight! making some odd clanking noise at low speeds.. i run 70 percent on road. I was wondering what other sprockets can i use with stock chain? I dont want to cut the chain but i will if needed. Just a complete noob here I love the feel of the bike with 17t x 50t... is adding a link to the stock chain a possibility?
To light a candle, is to cast a shadow.. |
04-23-2019, 10:23 AM | #2 | |
04-23-2019, 11:03 AM | #3 |
You can also get a half link if you just need a little more slack.
https://www.amazon.com/4-Pieces-Offset-Crank-Motorized-Bicycle/dp/B01MRC279B/ref=sr_1_fkmrnull_1?crid=3240AUCZ1EJGJ&keywords=42 8+chain+half+link&qid=1556031914&s=gateway&sprefix =428+half-link%2Caps%2C198&sr=8-1-fkmrnull Link is for reference. I would search for a better quality designed for motorcycles.
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 04-23-2019 at 11:49 AM. |
04-23-2019, 11:48 AM | #4 |
thank you guys! i ordered a dirtbike jack/stand, some of those 1/2 link, and a 45t rear sprocket! should be a fun couple of days!
04-23-2019, 11:49 AM | #5 | |
04-23-2019, 11:52 AM | #6 |
The 130 link chain should work fine with the 45 tooth rear.
04-23-2019, 02:00 PM | #7 |
You shouldn't need anything else once the 45 is in place on the rear.
04-24-2019, 08:13 PM | #9 |
Get a wee bit longer chain, I've run this 17/50 combo for 2 years and love it. I have a conventional chain, because at the time everybody got Hawk's so Amazon was out of X and 0 ring chains in the 428.
1983 Honda Xl600R 2016 Ducati Multistrada 1200S DVT |
04-29-2019, 01:36 PM | #10 |
13f/35r <----is this the combo for the 520 chain. sprockets?
04-29-2019, 01:58 PM | #11 | |
If you want to closely match a 17/50 then use a 12 tooth front for a 12/35 or a 13 front 38 rear
04-30-2019, 07:24 AM | #12 |
I'm running the 520 12/33 because I wanted to mimic the 428 16/45. I'm very happy with it, still has plenty of bottom end offroad and not buzzy at 55mph. I think I could get away with gearing it even lower because I'm nowhere close to topping it out in 5th gear.
