Old 09-26-2018, 10:17 AM   #31
Wow! you dug up a old one. lol I need to go back and revise my data a little.
Old 09-26-2018, 12:15 PM   #32
wamey   wamey is offline
wamey's Avatar
I found the thread on my UNI pod jet size search, had made a mental note to add my info to it back in the day as I like the idea of the thread, today is that day!
I think I'm going to go with megadan's setup with a slightly leaner main jet and needle setting to compensate for the stock exhaust.
Old 04-10-2019, 08:05 PM   #33
blksheep   blksheep is offline
blksheep's Avatar
Bike: 2019 CSC TT250
Elevation: 160ft
Carb: Mikuni VM26 "30mm" Clone https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Jet sizes: Genuine Mikuni Jets - 27.5 Pilot. 115 Main, mikuni needle and needle jet.
Needle setting: Center groove
Mixture screw: 2 Turns out from fully seated (engine pulls good through all gears with no hesitation. Good throttle response from idle to 1/2 throttle and 1/2 throttle to 3/4. Very snappy)
Relevant mods: Sprockets - (Stock gearing 17/50), two stage foam filter (42mm), Ebay exhaust, Air injection eliminated. Havent done a top speed run due to the fact that I am still breaking in the engine. I have had it up to 60 mph on a flat stretch and that was at 3/4 to 7/8 throttle. I weigh 170lbs
Old 04-10-2019, 09:44 PM   #34
DualSport   DualSport is offline
altitude: 800ft/244m
carb: PZ30 1.5 turns out on mix screw, 110 main jet, no needle mods, idle set while warm open choke at minimum rev without stall from stock pilot
Valves: both .00285 set cold(would like to know a balance tune that doesn't make a lot of noise)
That's a stock Magician with the iridium plug stock gap, T4 oil, and 87 octane. The coldest I've started it was 28F/-2C and had to go over all three choke stages in a three minute window do to the famous PZ30 pilot jet.. Around 60F/15C I can have it idle with open choke in under two minutes, and over 75F/24C not even use choke.
I've put the VM26 china clone on other RPS bikes here but my personal bike I haven't cause I could never find the real 30mm Mikuni..
Old 04-10-2019, 11:09 PM   #35
Updated to be relevant for 2024
2018 Hawk 250.
Altitude 1100ft.
Engine mods: WGK 1010851 292 Camshaft, Roller Cam followers, Motocult 70mm big bore cylinder kit and ported cylinder head, Kajimoto CRF exhaust with 440mm Yoshimura clone muffler. Nibbi Racing high output coil with a shortened lead, XD05F plug cap w/o resistor, NGK DPR8EIX-9 Plug,
Fueling: Mikuni VM26 "30mm" clone carburetor. 120 Main jet, 25 pilot, mixture 1 1/2 turns out, Needle 4th notch down.
Other mods. Dual foam pod filter. 520 chain and sprockets with 13 front and 33 rear sprockets Shinko 700 tires.
Top Speed - 75mph repeatable, 79mph peak in the right conditions.
She is my snarling beastie. Full Mod list in description link.
Old 05-28-2020, 10:37 PM   #36
bmw111   bmw111 is offline
bmw111's Avatar
2019 Hawk 250 -- stock other than changing to a PZ30 Keihin from eBay.
Main jet: 110
Pilot Jet: 45
Needle: 4th notch from top
Idle Mixture Screw: 1.5 turns out
Altitude: 1000 ft
Starts up with little to no choke (finally) and settles into a reasonable idle. No more stalling, sputtering, and warming up for 20 minutes. Feels much fatter throughout the rev range. Definitely more pick up from 50 to top speed.
Only issue I have is that once the bike is warmed up -- which doesn't take long now -- and I am riding anywhere from 10 mph up, it stutters or surges (not really a stumble) at around 1/8 steady throttle. Feels almost like a fuel injection model that is hyper sensitive and hunts between throttle on and throttle off.
Any ideas?
Anyway, much, much better than the stock carb and well worth taking the time to install a replacement.
Old 05-28-2020, 11:54 PM   #37
It would be a better idea to start a new thread so it doesn't clutter up this one with the discussion. We can help get you figured out!
Thanks for digging this one up again. Gave me a chance to revise mine lol.
To any new people out there, feel free to throw in your setups as well. I am going to include this as a link in my setup guide, so the more the merrier!
Old 05-29-2020, 11:35 PM   #38
bmw111's Avatar
Yeah, I thought about that but there are so many new threads on jetting issues that I thought I would be referred back to this thread.
I'll start a new one.
Old 05-31-2020, 09:03 AM   #39
Magician16   Magician16 is offline
Bike: 2016 Magician
Elevation:1500'
Carb: Factory
Jet sizes: 105 Kehein main, 42 pilot
Needle setting: Middle of needle
Pilot screw turns: 1 3/4
Relevant mods: NGK plug
Top speed: Cruises at 55 mph on speedo, haven't done top speed, will take gps when I do.
Last edited by Magician16; 06-03-2020 at 03:16 PM. Reason: New info. Top speed 59mph gps.
Old 05-31-2020, 11:04 PM   #40
Rocket tests   Rocket tests is offline
Rocket tests's Avatar
Bike: 2020 TBR7
Elev: 1000'
Carb: factory PZ30
Jets: 112 main, 38 pilot a/f screw 2 turns out
Needle: 1 washer shim
Mods: port'n polish head, decked 1mm and thin head gasket, foam filter in stock air filter location, stock exhaust, cat deleat, spark arrestor screen removed, 17 tooth front sprocket, stock rear sprocket, larger knobby wheels (hawk front rim & 19" stock rear rim), added oil cooler.
GPS speeds: strong 65mph and 75mph if the winds at my back.
Rider size: 6' 210lbs
Old 06-28-2020, 09:41 AM   #41
OldmanofMn   OldmanofMn is offline
Bike: 2020 RPS Hawk
Elevation: 750 ft
Carb: PZ30
Jet sizes: 110 main, stock pilot (40)
Needle setting: 1 shims
Relevant mods: air box mod,
Old 05-10-2024, 01:27 AM   #42
I dug this thread up from the dead. Mostly because I wanted to update it, but also curious to see if anybody wanted to add to it.
Old 05-10-2024, 09:05 AM   #43
Do©Hawk   Do©Hawk is offline
I put all that information in my signature so no matter what I post and where, the info is right there with my comment.
2022 Hawk DLX EFI
* 17T Front / 47T Rear / 428 x-ring chain
* Kenda K-760 front + rear
* Banjo brake light switch
* Custom cutting board skid plate
* Debadged (I don't like to brag about the
superior strength!)
* Top speed, GPS verified, as equipped: 68
mph (so far)
Old 05-10-2024, 04:39 PM   #44
Except this is a thread specific to carbureted bikes so other people could figure out an idea of how to jet their cg250 powered bikes.
Old 05-13-2024, 05:52 AM   #45
superjocko   superjocko is offline
Bike: 2024 CSC TT250
Elevation: 200 feet at home, but I also ride in the mountains of northern California mostly at elevations of 3000-6000 feet with occasional rides at higher elevations.
Carb: Nibbi PE28FL
Jet sizes: Genuine Nibbi 115 main and 35 pilot.
Needle: The needle that came with the PE28FL, as delivered. It has no markings on it that I can see.
Needle setting: 2nd groove from the top
Pilot air screw turns: 3/4 - 1-1/4 turns, depending on elevation
Top speed: 70-ish on GPS, and dependent on many factors
Relevant mods: Motocult Stage 3 kit, 20mm I.D. tailpipe installed in an otherwise stock exhaust system (with catalytic converter still installed), NGK DPR8EIX-9 spark plug, and 16/45 sprockets. The stock air filter, air box, and pulse air injection system are all still installed. Additionally, I have retained the stock evaporative emissions charcoal canister and have its purge hose routed to the bowl vent fitting on the Nibbi carb. That method of connection for the evaporative canister does have a VERY slight leaning effect on the jetting since drawing air (that contains fuel vapors) through the canister is ever so slightly more restrictive than just having the bowl vent freely open to the atmosphere.
I tried of number of jetting combinations, changing one thing at a time, until i settled on this setup that I'm very pleased with. I chose the 115 main jet and #2 needle clip position as a compromise for the range of elevations that I fairly regularly ride. It's a little lean at wide open throttle at my home elevation and will noticeably, but not horribly, ping on 87 octane fuel if the engine is loaded heavily, like pulling a steep grade. Running 91 octane eliminates the ping and it's not so lean that it causes any particularly noticeable effect. I can back out the pilot screw and adjust the idle speed thumbwheel as necessary to compensate the part throttle mixture and idle speed for riding at higher elevations.
I ride the range of elevations that I indicated (200 feet to 6k+) regularly enough that I don't want to have to keep changing jets all the time, so this is what I've settled on and it works very well for my circumstances. Fuel mileage is 60+ mpg with a combination of road and trail riding that favors more road riding. In all reality, with the pilot air screw at 1 turn, this jetting is likely about ideal for this bike at 3000-4000 feet elevation. The same setup with a 120 main jet, and the pilot air screw at 3/4 turn, is about ideal at my home elevation. Of course, temperature, humidity, and other things that affect air density will vary.
-2024 CSC TT250, stage 3 motocult kit, Nibbi PE28FL with custom-made cable controlled choke, modified stock muffler (larger diameter tailpipe), custom oil cooler installation with relocated stock evaporative emissions canister, oversized stainless steel footpegs, IMS folding tip shifter, a few little blingy bolts and bits. More personal preference mods to come.
