04-26-2018, 09:33 AM | #1 |
Magician assembly, synthetic oil?
So I just bought and assembled a Magician. It started right up (looked like it was on fire). It doesn't like to idle, but I'm assuming I can up the idle screw and have some more luck.
So a few questions: I'm going to run 15w-40 diesel oil for the break in period. Can I switch to 4 stroke 20w-50 synthetic down the road or do I need to stay with non synthetic? The front brake caliper seems to be free floating. It is attached with pegs and a two boots, no screws holding it in place. Is this normal? Any recommendations on avoiding disc rub? I want to keep it stock for now (minus a NGK plug), has anybody else had idle issues? Thanks |
04-26-2018, 09:38 AM | #2 |
I don't know about the china bikes, but you may need clutch plates made for synthetic oil or the clutch will slip, it did on my old jap bikes.
04-26-2018, 09:40 AM | #3 |
I would use conventional oil until you have about 500 to 1000 miles on the bike. Synthetic oil can be to slick for proper break-in on these old style engines. I use Rotella T 15w40 diesel oil. It has all the additives that a motorcycle clutch likes.
04-26-2018, 09:45 AM | #4 |
Was the synthetic oil an automotive oil? If so, that is why. Automotive oils for gas engines have friction modifiers that will kill a motorcycle wet clutch quickly. Motorcycle clutches can handle synthetic if it's for a diesel engine or motorcycle specific oil. I have ran synthetic in my old GS's that are notorious for slipping clutches and the synthetic has not caused a problem, but the oil is a bike spec synthetic oil Valvoline.
04-26-2018, 12:09 PM | #5 | |
04-27-2018, 12:42 AM | #6 |
The easiest way to fix the your idle problem with your Magician is to buy a new carb the stock carb comes sealed but you can still get it opened to clean it. I bought one for $22 and it worked great on my first Magician. I have several video on the Magician on my YouTube channel, my channel is just called DZ.
assembly, magician, oil change |
