04-20-2018, 03:48 PM | #151 |
Droping the motor would make things way easier. But you can also try disconnecting everything, including the subframe from it's top mounting to the main frame and the swingarm axle from the engine, and pivoting it, with the engine still attached, to the front/down. You -may- get enough space on top to remove the valve cover, head, and cylinder. Haven't tryied though, and my own kit is a couple months in the future.
04-23-2018, 10:36 AM | #152 | |
06-07-2018, 11:49 AM | #153 |
Hi,
I dont know if it is helpful. I am from Vietnam and we have many motorbike running delphi which are Benelli and Brixton, Some model reported the same case, usually ODO above 4000. there are actually 02 things i did. 1. check the temperature sensor, try to replace it. 2. unplug the o2 sensor so the bike running on open loops always. |
