Old 02-03-2018, 04:56 PM   #61
zach3697   zach3697 is offline
Put the exhaust on and then try to run it before assuming a carb problem. No exhaust at all will throw off the carb tuning, and it won't want to idle or run correctly.
So I ran into a dilemma. I went ahead and installed the muffler and started it up and still wouldn't rev until it warmed up a little. After it warmed up a but I was reving it a bit and it sounded great! Then all of a sudden it shut off. I tried a shot of starting fluid to see if it was a fuel problem but nothing. Took out the spark plug to so if I had spark and it has a blue spark. So now I'm stumped at what todo. It has fuel and ignition and plenty of compression.
Any idea?
Old 02-05-2018, 12:58 AM   #62
So I went ahead and checked all the connections on the bike and made sure everything was tight and still nothing. Went ahead and ordered another spark plug, coil, and cdi to try and rule stuff out. Will give an update once I get those parts in!
Old 02-05-2018, 02:12 PM   #63
What jetting is in the current carburetor?
Old 02-05-2018, 03:09 PM   #64
The carb is stock. It still has the tamper resistant screws in it
Old 02-05-2018, 06:26 PM   #65
The stock jetting is terribly lean. Makes for hard starts and cold idle issues like you are experiencing. Need to jet and tune that stock carb at a minimum
Old 02-05-2018, 07:50 PM   #66
Even so, I thought I ruled that out by using a shot of starting fluid and I didn't even get a pop out of it. That's what led me to believe it was an ignition issue. Also I already have a set of new jets but I'm just trying to get it running
Thanks!
Old 02-06-2018, 01:31 AM   #67
sounds like you have the choke on full!
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 02-06-2018, 01:35 AM   #68
Well Today I got the motor back installed on the Hawk. Bolted everything except for the exhaust because I wanted to make sure it ran before I put it all back together. It didnt start at first but after some convincing i got it to start and idle. The video is below. The only issue is when I give it any throttle at all it dies. Im assuming its a carburetor issue that ill have to look at later but thats the update for now!
yep sounds like choke is on
2016 hawk
kaw h1 400 tripple
Old 02-06-2018, 01:36 AM   #69
idling rather slow too
2016 hawk
kaw h1 400 tripple
Old 02-06-2018, 08:51 AM   #70
I had it on first to get it started I have tried in half and open as well
Old 02-06-2018, 11:52 AM   #71
Checked the kill switch?
Old 02-06-2018, 08:28 PM   #72
That's the thing tho. I get spark but the motor does even pop. So that means the kill switch should be fine right?
And its getting fuel because of that shot of starting fluid which should get it to pop. So I'm just thinking that the ignition coil could be week or the cdi or something. All the parts came in tonight. Just have to hook it all up and see. Just to confirm the CDI is DC and not AC right?
Old 02-08-2018, 08:17 PM   #73
Well I think this story is coming to an end. I went ahead and replaced the sparkplug and the ignition coil and it fired right up. Finished buttoning it up and took it for a ride! I know I have a little ways to go, like jetting and tuning the carb. Does anyone know where I can get cheap platics for the bike?
Old 02-08-2018, 08:19 PM   #74
Merlin   Merlin is offline
Thumbs Up
Taobao look it up on this site. Your bike is sounding sweet. Well done.
Bashan Blaze
Mods: Alloy Rim's, Muffler, Mukuni VM26 Carb, Foam Filter, Tachometer, Volt Meter,LED Headlight, LED Blinkers
Old 02-08-2018, 08:51 PM   #75
Excellent work. Sounds nice and healthy now.
As far as plastics, the tank and side panels can be used from a tt250.
