Old 09-25-2017, 04:05 PM   #1
tinknokker3   tinknokker3 is offline
08 roketa buggy cdi issues
I have a roketa buggy that has the 260 CC engine and I lost sparking it. I replaced the coil, plug, stater, voltage regulator,and cdi box. Everywhere I've looked it says an 8 pin cdi box but not what rpm it is. The first cdi box I used would get the engine to POp but not start, so I found a cdi box that had a 7500 rpm spec and lo and behold the bigger started right up. Finally I thought, well it ran for a couple of minutes and when I went to take it for a spin I backed up ten feet and it died.. blew cdi box. Any insight would be very helpful thanks.
Old 09-25-2017, 05:23 PM   #2
katoranger's Avatar
Is it an AC or DC CDI?
Old 09-25-2017, 05:24 PM   #3
Adjuster's Avatar
Possible short in wiring. Just start tracing all wires in and out of the cdi box until you find a burnt one touching something it shouldn't. Sometimes it actually helps to get your head in there and sniff around to find the burnt wiring.
Old 09-25-2017, 09:04 PM   #4
humanbeing's Avatar
Those Yamaha clone/ Linhai or whatever is 100% dc...
Old 09-26-2017, 07:27 PM   #5
So I guess my question then would be, which is the right cdi box for this engine.. I've tried three different 8 pin types with no luck, and I knw for sure its the cdi box.
Old 09-26-2017, 08:14 PM   #6
humanbeing's Avatar
Are there reliable DC source to CDI? BAD battery: The voltage after E-starting may drop to a level that CDI won't accept...
What's the peak voltage of pickup? Low reading indicates the gap btw flywheel isn't right... http://chinariders.net/showpost.php?...1&postcount=17
