#46 |
I haven't heard any updates, but I might call CSC and ask about it.
#47 | |
![]() I suggest you remove the spring and pump the forks to remove all the old fork oil. After removing all the old fork oil, I recommend you fill each fork with 330 ml of new fork oil. The job isn't hard, and I'm sure you will be glad with the results. ![]()
#48 |
use fork oil not ATF....
ATF is for lubication and has a high firm strength compaired to fork oil & that firm strength is the problum it captures air bubbles to easly and dosn't release them quickly... so the oil weight or CST rating is all over the place depending how much air it is holding... fork oil is designed not to froth up as it is pushed though the holes /valves & has a low firm strength that dosn't capture air easy but if it dose it releases it quickly... but that being said the RX3 / hawk and others ATF is prob usable as the suspension has limited quite slow travel in it's intended use.. but there is far better oil out there designed for the job... Lintern the guy that builds my suspension has a saying.. "you only know as good as you have riden" ..
#49 |
"Assembly is the opposite of the disassembly procedure."
Can someone provide advice on getting the inner seal seated? I tried tapping with a screwdriver, but am reluctant to tap hard and damage the seal. I've tried pounding the upper and lowers together (opposite of the disassembly) but the dust seal gets into place and the inner seal still isn't seated enough to get the C clip in place. I then cut a 1" length of PVC pipe, hacked a section off so it in a C shape, stretched it over the lower tube, and trying slamming it the tubes together again, but the PVC is riding up on the dust seal and I don't want to damage it. I also tried some lite hammering with no advancement. I then cut a 5" length of PVC and stretched it over the tube and tried slamming it down onto the seal, but the PVC is just too lite. I was able to get the washer and seal seated in the upper tube while the lower tube is removed, just to confirm it can go back in there. I'm wondering if I should try installing the lower tube with the seal already seated in the upper? There will be a few tricks on getting those bearing rings on, but maybe it can work. |
#50 |
#51 |
Setting the fork oil seal is easiest with a fork seal driver of the appropriate size. However, if you don't have a fork seal driver, you can use the method shown in the following video.
#52 |
Old Fork seal! So simple!
![]() Thanks for the tips!! |
#54 |
Revisiting this older thread.
For the first time in my life, I'm not completely happy with my tried and true Bel Ray 10W fork oil that I've run in every bike since I was a teenager. It just seems the RX3 has a bit too much jarring on the elbows (that goes all the way to your teeth) on some of our really pocky "paved and constantly patched" goat trails. I was first searching for some progressive rate springs (without success) but I may try the 7.5W ATF this time, just to see if it softens up the initial 2" of travel. After I get in to some heavier stuff and the forks are more compressed, it's fine. It's just that initial first couple of inches that need to be more forgiving. Has anyone had success working with this?
#55 |
I used the Valvoline MaxLife Dex/Merc ATF in the forks of my Zongshen ZS200GY-2. It has the viscosity you desire, and does an excellent job. If you like, refer to post #13 and post #14 in this thread.
![]() http://www.chinariders.net/showthread.php?t=14672
