Old 06-02-2017, 02:06 PM   #16
Originally Posted by joker View Post
Thank you I'll check once I'm out of work!
Should look like this one ( picture by hertz9753)
Old 06-02-2017, 02:13 PM   #17
Ariel Red Hunter's Avatar
Hello so I just purchased a new battery but for some reason I can't get any power. I can kick start the bike and everything lights up but no power when I turn the key and use the battery to start it. Please any suggestions?
One of the first things to check is the battery ground, where it attaches to the frame. Just because it looks good does not mean that it is good. Often, there is paint on the frame whwere the battery ground is attached. Paint is a so-so insulator. It will permit a low watt current to come back from the frame, but the paint stops the high wattage pull of the starter motor...ARH
Old 06-07-2017, 08:57 AM   #18
goat67   goat67 is offline
goat67's Avatar
Reconnect or enable the remote and then try to use it to start the bike.
I had an issue where I needed to do this to get it to start with the starter, also.
2016 Brozz
brozz, hawk
