05-31-2017, 07:15 AM | #1 |
Source For Sprockets
I am looking to change the gearing on my following bikes:
ADR125-2 / 154FMI AGB-36C / 166FMM I am trying to find the sprockets locally, or worst case North America. I would prefer to not wait 30-90 days for them to arrive. Any tips where I can find sprockets to fit these bikes? JT Sprockets seems to be the oddball and post the dimensions of their sprockets... sadly none of the ones I checked fit. Thanks, Ross |
05-31-2017, 09:11 AM | #2 |
Any pic???
Find out the type 420/428...1st Measures & compares those pic in JT catalog. If still can't find it, ask http://www.jtsprockets.com/contact w/ EXACT measurement...
05-31-2017, 09:22 AM | #3 |
The ADR125-2 / 154FMI is:
428, I am looking for 12 or 13 tooth The diameters are 14mm, 17mm with a 4mm flat or whatever it is called. The bolts are 5mm and 30 mm apart. The AGB-36C / 166FMM is: 530, I am looking for a 12 tooth The diameters are 18mm, 20 mm with a 4mm flat. The bolts are 5mm and 34 mm apart. I scoured the JT catalogue as best I could last night. I was not able to find a list, I had to go sprocket by sprocket... fun times ;-) I will contact JT, thanks for the help. |
05-31-2017, 09:52 AM | #4 |
[ADR125-2] 428: JTF273 420: JTF249
[AGB-36c] No idea yet
05-31-2017, 10:03 AM | #5 |
Thanks, You did what I could not last evening!
05-31-2017, 10:11 AM | #6 |
36c: https://translate.google.com/transla...496&edit-text= said that's a Loncin
05-31-2017, 10:25 AM | #7 | |
05-31-2017, 10:42 AM | #8 | |
They also have a 428-13...
Any experience with delivery times from them? Quote:
06-01-2017, 08:43 AM | #9 | |
https://www.aliexpress.com/item/530-...436722577.html
06-01-2017, 01:19 PM | #10 | |
You are awesome, thank you very much for all of your help.
I did learn something. Searching for 530 12 is not the same as searching for 530 12T... I guess I should have known. Lesson learned/relearned. Quote:
07-10-2017, 09:36 PM | #11 |
530 12 TOOTH 20MM FRONT ENGINE SPROCKET ATV HONDA YAMAHA DIRT BIKE GO KART ES46 https://www.amazon.com/dp/B00EOBZ5DS..._vMczzbX8NV3W6
Just found this sprocket, looks like the listed dimensions match what you're looking for. Hope i got the link right. |
07-11-2017, 07:55 AM | #12 | |
I ended up going with buying blanks for my rear and machining them. Or at least, I have bought the blanks but have not got around to machining them yet ;-) |
07-11-2017, 05:08 PM | #13 |
I went ahead and placed an order for one of the Amazon sprockets i linked for my AGB-36, I'll let you know if it works out.
Update. The Amazon sprocket bolted right on, and works great. Last edited by Rider dad; 07-24-2017 at 08:45 PM. |
