04-17-2017, 12:33 PM | #31 |
If the six speed transmission is inspired by Honda, there is simply an extra gear between 2-3 or 3-4 (can't recall which); it's not likely to be an overdrive gear. Think of it more like a close-ratio transmission that always allows you to be in the ideal gear for racing.
I can't figure out the design of this motor. The dipstick is in an odd position to be copied from Honda, yet the clutch arm is on the correct side. There is no visible bump for the countershaft, hinting that it's designed more like a KLR250. Hmm... I suspect it would bolt in to any Honda-inspired China bike.
04-17-2017, 01:48 PM | #32 | |
6 Gear-Primary 3.33 1st Gear 2.909 2nd Gear 1.867 3rd Gear 1.389 4th Gear 1.15 5th Gear 0.95 6th Gear 0.80 5 speed specifications- "Primary: 3.333; first gear: 2.909,Second gear: 1.867; third gear: 1.389,Fourth gear: 1.150; fifth gear: 0.9545 "
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 04-17-2017 at 03:08 PM. |
04-20-2017, 11:56 AM | #34 |
Thanks for posting the specs, Jerry.
09-25-2019, 05:37 PM | #35 |
After seeing that video Jerry posted I want one of those. The comments appear to be in Spanish or porchagese so they must sell them in South America. Just have to make it across the US boarder. Heck, if coyotes are doing it on foot I could easily make it with a full tank! Time to take a bird to South America and road trip it back to the US. Whose coming with me?
09-25-2019, 06:00 PM | #36 |
https://images.app.goo.gl/Z2XdakXEvk2U9FhD8
Also saw this sweet cafe racer when I google the re250 motor |
09-25-2019, 09:28 PM | #37 |
It should be noted that the 6 speed transmission also means no kick start. That is the trade off.
09-26-2019, 04:34 AM | #38 |
It was the same way with the CRF230s... They had a kicker at first, but the gears were too weak and they had to redesign the transmission, eliminating the kicker.
09-26-2019, 09:45 AM | #39 |
I'm willing to lose the kicker for a 6 speed.
09-26-2019, 06:41 PM | #40 |
I would also trade the kicker for a 6th gear. Probably just wishful thinking that you would actually get it. Would suck for customs to take it and lose the $750. Really actually crappy situation. They know when someone gets these bikes or other bikes they will be modded and not be in compliance but they still make it a requirement.
09-26-2019, 09:36 PM | #41 | |
09-27-2019, 08:15 AM | #42 | |
https://www.ebay.com/itm/250cc-engin...75719522fa6c73
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 10-01-2019 at 08:56 AM. |
09-27-2019, 08:44 AM | #43 |
Still only 223cc not 249cc which is 15kw or so
GPX what engine is in there bikes? 232.6cc or 223cc? It’s very expensive or complex to ship, these engines are not sooo eco since here but shipping is a mare as I looked into it etc |
09-27-2019, 09:02 PM | #44 |
The other weird thing is companies buy parts and assemble engines them selves....
May not be a loncin assembles engine but made from parts from..... Who knows |
09-27-2019, 09:08 PM | #45 | |
