Old 04-17-2017, 11:13 AM   #196
Merlin   Merlin is offline
Originally Posted by goat67 View Post
Can you point me in the direction on the issue with the bike would not turn off mine did this once..... I thought it was because I used the remote starter.
Yes if I remember right if you start it with the remote you have to stop it with the remote. Just the way it's made.
Bashan Blaze
Mods: Alloy Rim's, Muffler, Mukuni VM26 Carb, Foam Filter, Tachometer, Volt Meter,LED Headlight, LED Blinkers
Old 04-17-2017, 11:15 AM   #197
goat67   goat67 is offline
goat67's Avatar
Thanks. On another note why do these bikes not have a kill switch?
2016 Brozz
Old 04-17-2017, 11:17 AM   #198
Azhule   Azhule is offline
I never used the remote start... and the remote start/alarm system was the first thing I removed/bypassed on the bike...
Our bike just flat out refused to shut off until I fixed the solder points and wires
Old 04-17-2017, 11:20 AM   #199
My Bashan does on the right side cluster.
Bashan Blaze
Old 06-26-2017, 04:56 PM   #200
Went for a nice ride today up to Harbor Freight, got a spring compression tools, some more boxes of nitrile gloves, and a few other goodies while I was there... the looks on everyone's face when they see you stuff everything into a backpack, put a helmet/gloves on, hop on the bike and ride off was well worth the trip...
Got to lane split several times due to "morons and me not feeling safe"... or maybe I just wanted to lane split while it was HOT outside, traffic was being slow for no reason, lanes started backing up fast... and I had that excuse ready in case I was pulled over for doing so
Only one person was distracted on the phone today during my ride, everyone else had their head on a swivel and made eye contact with me several times... really amazing when you think about it... but today is a fluke day in my book... it will be back to "kill all invisible motorcyclists while I txt" tomorrow
Don't know why our Bashan WILL didn't come with one, it's only 14 cents worth of plastic and wires after all
Old 06-26-2017, 11:51 PM   #201
Kill sw...manny parted it for another bike
Old 09-19-2017, 10:49 AM   #202
So there I was getting the China Bike ready for a weekend ride with Detours... and the Bashan license plate, brake, and turn signal holder finally decided it was time to fall apart into 14 pieces... soo I started looking around pops garage and found a (free) replacement...
If anyone else has the same problem, I found that an old License plate off a car will work as a substitute only need a hammer, a drill and some bits, a file, and a cutting tool to complete the yob
Took this pic when I was almost done, just had the right side to cut, fold, and reattach the turn signal... I might paint it black and put some kind of rubber around the sharp edges, but other then that I'm a happy recycling camper because the China bike is once again "on the road"
Old 11-09-2017, 07:56 PM   #203
franque   franque is offline
You mentioned being willing to post up on how you installed a COP for your bike, could you give me details on what you used? If you want to post up details for install, that'd be great, otherwise I could probably figure it out.
Old 11-11-2017, 02:26 PM   #204
"Idle Hands"
I found a "2 wire" Denso Coil On Plug (and connector/wire harness) that would "fit" my motorcycles, modified stuff to get it to actually "fit", then it's as easy as power to power/ground to ground and you are good to go with a stronger spark across the entire rev range
Haven't really talked or posted about it because no one else really wants to do all that work "to get it to fit"... they figure at $6 for a dozen Chinese coils it's not worth the hassle and $$ for the reliable Denso made in Japan COP mod ... they just carry around a spare or two and call it good
Thanks for stopping by
Old 11-11-2017, 04:10 PM   #205
What are those COPs off of?
Old 11-23-2017, 08:28 PM   #206
Runs without a battery!
I know the Lithium battery is already really light (about 1lb) but another thread got me thinking...
"I wonder if I can remove some more weight off the China bike and run it with only the kicker"...
Turns out I can drop the weight of the battery and starter if I really want to it (kick) starts first try and runs great even without a battery the neutral and high beam dummy lights flicker on and off with the engine supplying power but that is the only thing I noticed "wrong" during my tests
Also working on a "Tuned Intake", going to try several different pipe lengths to try and maximize things around 5,100 rpms on the '3rd or 4th harmonic wave'... it's going to be a fun winter
Old 11-24-2017, 08:54 AM   #207
Ariel Red Hunter's Avatar
Ahh, the un-foreseen advantages of magneto ignition...ARH
Old 11-24-2017, 09:19 AM   #208
I prefer a kill button. I used a horn button off of an English bike (available on e-bay nowadays). Run a wire from the magneto wire, somewhere before the coil to the button where it is "T-eed" and run back to the coil. Solder a small piece of wire on the other side of the button, strip about a half inch of the other end, and lay it across the clamp that attaches it to the handlebar. You can even paint it red with fingernail polish before it goes to inspection, if they are that anal. Now youre key switch only controls the electrical system, and the magneto ground controls the ignition system...ARH
Old 08-17-2020, 08:43 PM   #209
oincman   oincman is offline
Valve Lash
I know this is an old thread, but do you still have this bike? If so, what did you set the valves to? Just picked one of these up and the valves were damn near closed (so it didn't make any valve noise).
Adjusted both to .005 now I hear the valves (like my old Hawk).
Do you hear valve clatter on yours?
