Old 04-05-2017, 06:09 AM   #181
chuck   chuck is offline
Looking forward for the new design too
Old 04-05-2017, 07:55 AM   #182
Can't wait to see it.
Old 04-05-2017, 01:29 PM   #183
mjstef   mjstef is offline
So this is another style they sell in China. It replaces the oil plug and screen. Only $5 difference in price but hoses cannot be cut to length. I am ordering 1 of them to see if it will work out. I'll try to fit it on my bike. Their is a possibility of cutting the crimp off the hoses on one end and using a hose clamp like the ones i have currently.
Old 04-05-2017, 01:36 PM   #184
I actually like that better. I assume that is a filter in line?
Old 04-05-2017, 02:27 PM   #185
Merlin   Merlin is offline
That's a very nice cooler setup. That one should be able to take a thermostat.
Bashan Blaze
Mods: Alloy Rim's, Muffler, Mukuni VM26 Carb, Foam Filter, Tachometer, Volt Meter,LED Headlight, LED Blinkers
Old 04-05-2017, 02:27 PM   #186
Yes that is a filter.
Bashan Blaze
Old 04-05-2017, 04:30 PM   #187
Diggin' it. Mrs. 2LZ TT250 may need one of these.
Old 04-05-2017, 06:30 PM   #188
goat67   goat67 is offline
goat67's Avatar
This one looks interesting keep us posted.
Old 04-05-2017, 08:13 PM   #189
rwl6935   rwl6935 is offline
rwl6935's Avatar
I hate to say it, but I think an oil cooler will do a whole lot of nothing using that configuration. If you think about it, you'd have to literally have the hoses and cooler filled with oil and the oil be continually moving before any cooling can take place. How's the oil pump up into the cooler? I know the crackcase gets pressurized, but would it be enough to push the oil through the cooler? It may do more harm than good. I could be wrong though.
I wonder if the instructions say that more oil needs to be added once the unit is installed?
Old 04-05-2017, 08:23 PM   #190
rwl6935's Avatar
Whoops! Didn't realize you were designing it.
My questions are -
do you need to add more oil to compensate for the oil that's supposed to be in the cooler and lines?
How is the oil getting pushed through the cooler? Assuming the drain port has a push and draw setup Is there enough pressure to get the oil up there?
Just curious
On the hand guards - count me in
Old 04-05-2017, 09:42 PM   #191
My questions are -
Just curious
I have been running one for the last 200 miles. It warms up right away. According to my supplier they send a bunch of them to South America and the desert areas of China. I know it helped my hot shifting.....
Old 04-05-2017, 09:48 PM   #192
My questions are -
Just curious
That's not a drain port. The drain port in on the bottom of the engine. That's were the screen filter is located. The oil pump the oil through that filter.
Old 04-06-2017, 06:21 AM   #193
kohburn   kohburn is offline
kohburn's Avatar
in place of the oil screen eh? that means it would cool all the oil being fed to the engine not just a portion of it?
-whatever you do, just be awesome.
- 2008 Kawasaki Versys
- 2016 CSC TT250
Old 04-06-2017, 09:56 AM   #194
Ariel Red Hunter's Avatar
Bit of a delay. During QC they found the mold was out of wack and a bunch didn't pass inspection. They have 5 that passed QC and another design that supposedly fits in place of the oil screen by the shifter instead of a replacement valve cover. Will be getting a sample of one of those as well. Mid next week the way it sounds....
I like the concept of the new design better. Oil line length should be no problem. Any farm equipment dealer either can make up hydraulic hoses to order, or has a local shop that does them. Metric as well as SAE...ARH
Old 04-06-2017, 11:56 PM   #195
pcspecialist   pcspecialist is offline
Now you have me interested.
