03-07-2008, 09:53 PM | #1 |
Stock sprocket size?
On a LF 200 what is the sprockets sizes? front sprocket and rear sptocket.
03-07-2008, 11:22 PM | #2 | |
Re: Stock sprocket size?
Buyingchina |
03-07-2008, 11:32 PM | #3 |
I assume that is the 200 III and not the B?
"Be excellent to each other" "We are all human. Let's start to prove it!" |
03-08-2008, 12:12 AM | #4 |
Thanks Jim, I added that info to my original reply.
I'm getting old. Well, that's my "official" excuse anyway! Buyingchina |
03-08-2008, 01:28 AM | #5 | |
03-08-2008, 01:38 AM | #6 |
They're different models... I think really the main difference is the fairings, but I've never owned either of the bikes... However the B has different sprockets then the III... Your's is most likely a III.
Here is a picture of the B on the American Lifan website,
03-08-2008, 02:22 AM | #7 | |
03-08-2008, 02:49 PM | #8 |
Major differences between the LF200-III and the LF200-B,
1: The 'B' has dual front disc brakes and a single rear disc brake vs a single front disc and a rear drum. 2: The 'B' comes with much wider tires, improving handling. 3: The 'B' has a new frame which is supposedly much better than the 'III'. The down sides, 1: The 'III' has 1/2 kw more power than the 'B'. 2: The 'III' is about twenty or so pounds lighter Than the 'B'. 3: We have rear 520 rear sprockets ready to go for the 'III' made in a high grade aluminum. EDIT: The 'B' also has 428 setup vs the 520 drive train on the 'III'. You can add wider tires (Front/Rear) as I have on my LF200-III for under $300. Here is a thread on my site discussing the evolution of my LF200-III, http://lifan-moto.com/yabb/YaBB.pl?num=1201313252/0 Almon |
