03-24-2017, 10:33 PM | #17 |
On the road today and passed thru Victoria. Sorry if I blow up thread using my crapnot so smart phone. Must be bombing these across the nation. I noticed the height too but its a good thing IMO. Also I mentioned that the seat was stiff and sales guy also agreed. Suspension was tight but as expected and I sure it probably is adjustable. Said it was just built yesterday And put out to on the floor. Yes the clutch pull was nice. No didn't leave with it but it is very niceand jap quality standard. From dale fun center in Victoria Texas today
03-24-2017, 10:41 PM | #18 |
IMO. Kaw trying to ride the fence between entry level street consumers and low weight adv'ers. Sales guy said I think 386 lbs. That is big draw lower weight with higher HP ability
03-25-2017, 11:18 AM | #19 | |
As long as the RX (and sister bikes) don't start exploding and CSC continues to keep a good rep, more and more people will check them out from sticker shock at the Big 4. That's exactly how I got into CB's. I almost fainted in a Yamaha shop.
03-25-2017, 12:32 PM | #20 | |
Skid Plate
The safety of the exhaust system on the 300X is also a reason I'm looking at the BMW G310GS. It has a very unique exhaust system that exits the engine from the rear of the engine, very similar to the Cannondale dual sport motorcycle of quite a few years ago, before filing for bankruptcy. No need to worry about the possible damage to the exhaust system. |
03-25-2017, 03:05 PM | #21 |
Why do almost all motorcycle engines have exhaust that exits on the front and intake on the back?
To me it makes more sense to have intake on the front (ram air potential) and exhaust exit at the back of a 4-stroke. Exhaust on the back would probably be better for air cooled engines as well. Plus exhaust systems could be made shorter therfore bikes could be made cheaper. It would be a mess if you tried to fit a 2-stroke exhaust behind an engine. |
03-25-2017, 07:15 PM | #22 | |
03-25-2017, 08:07 PM | #23 |
Building a motorcycle one has to think about where that engine will live, relative to the wheelbase. In most cases you want the weight to be distributed 50/50 front to rear. If you put the intake on the front that means you have to position the bulk of the engine farther back so the intake tract (fuel injection, air box, etc) do not hit the front wheel. Most manufacturers opt to put the exhaust side fwd and intake aft so it is easier to package everything. Maybe BMW has figured a way to make this work, time will tell.
Peter Y. |
03-25-2017, 08:10 PM | #24 | |
jb
03-25-2017, 08:26 PM | #25 |
I've got nearly 15k miles on a Ninja 300, I know that mill pretty well.
I will say that exhaust is utter dogshit, and it traps a lot of moisture under that heatshield which is particularly annoying for the midpipe clamp, which corrodes fast. There's a lot of aftermarket solutions, though, most are stainless. 300 is not known for great fueling below 6k, I'm guessing they've tuned this bike accordingly as I had to get a fuel controller to sort mine out. I think 39HP is very optimistic, although I do note those header pipes look a lot less restrictive than the Ninja 300. Conventional wisdom says that an aftermarket exhaust system and tune on the 300 is worth about 5-7hp. |
03-25-2017, 09:11 PM | #26 | |||
google is your freind... ..
03-25-2017, 10:18 PM | #27 |
The WR250? Header at the front, intake at the back, isn't it? Unless I'm misunderstanding.
03-26-2017, 12:05 AM | #28 |
barrel leans backwards 10*... intake at the front.... exhaust at the back... fuel tank under the seat...
03-26-2017, 09:03 AM | #29 |
NZ version might be different. The USA models still have forward exhausts, at least according to Google.
Horse holder at Madame Orr's House. |
03-27-2017, 12:14 PM | #30 |
Let's not forget that the hottest part of the engine are the exhaust valves, exhaust ports and header pipes. I'd imagine that keeping that in the front in the cool air flow may have something to do with it???? Just a guess. I'm no engineer nor so I play one on TV.
