#17 | |
Fantastic idea! You inspired me to snatch one up off of EBay that has 2 USB ports for charging devices on the go. Under $12 shipped, how can you beat it? |
#19 |
I was looking at something similar except it has 2 USB ports. I was trying to figure on how to mount it. Now I know how.
#20 |
Installed +12V external socket. No more problems with charging the tablet, the smartphone, etc. on the go (with adapter). One may connect a small compressor if a flat tire somewhere on the side of the road. No need to remove side cover to charge the battery periodically during long winter shutdown.
Purchased here for $1.50 - http://www.ebay.com/itm/Waterproof-1...kAAOSwSdZWglPQ ![]() ![]() ![]() ![]() |
#21 |
Where are ya'll picking up power for the voltage meters? If I add much more, I'll need to add an aux power block.
2002 Goldwing 2016 Hawk |
#22 |
I would wire the volt meter into one of the many "Key/Ignition ON" sources... grab a volt meter and find what you need
#23 |
Great write up and my God that thing is clean! I thought mine was looking good smh....
2005 Kazuma Cheetah 200 (Swamp Thing) |
#24 | |
![]() Last edited by green_hawk250; 03-25-2017 at 06:45 PM. |
#25 |
Which shifter boot did you order and how long did it take to get it?
#26 |
Suggestion for your seat; do as I did but add padding between the Coleman Comfort Ride and your seat.
#27 | |
It took about three weeks, don't remember exactly. |
#28 |
I like your idea, but I am planning totally reconstruct the seat with adding and reshaping foam padding inside. I have already purchased nice marine vinyl cover from Hobby Lobby.
#29 |
Did you ever get around to doing it?
#30 |
Please check my thread - http://www.chinariders.net/showthread.php?t=19578
