03-06-2017, 02:05 PM | #106 |
un blot it
03-06-2017, 02:08 PM | #107 |
You'll need a torch and a cut off saw No just remove the bolts that hold it together.
03-06-2017, 02:10 PM | #108 | |
The bolts are welded shut |
03-06-2017, 02:13 PM | #109 |
On mine the nuts were welded to the angle iron but not the bolt. Do you have a angle grinder to cut the welds?
03-06-2017, 02:37 PM | #110 |
Om mine there where enough un-welded bolts to take the frame apart.
03-06-2017, 02:47 PM | #111 | |
I will get them off, just a little more time involved. |
03-06-2017, 03:44 PM | #113 |
Was looking at the exhaust it has a huge converter behind the heat shield..the exhaust in not like the brozz either,,,the end cap is riveted on and I don't think the spark arrester can be removed,,,its got a really long exhaust on it
03-06-2017, 03:55 PM | #114 |
Sounds like a CA bike! All of my end caps/baffles/spark arrestors have been welded in.
03-06-2017, 04:13 PM | #115 |
Pictures I'm anxious.
03-06-2017, 05:02 PM | #117 |
All this negative thinking Pop rivets? That's what they make drills for. Welds?? That's what they make grinders for. lol Come on man, think out the box . Still waiting to see who will have there pictures of the whole bike up first. The race is on. lol
03-06-2017, 06:30 PM | #118 |
Locks, that is what they make bolt cutters for. Incarceration, that is what they make parole boards for.
03-06-2017, 11:16 PM | #119 |
Very slow progress
03-07-2017, 12:17 AM | #120 |
Some people have held their bike up by chain or strong rope hung from the ceiling of their garage. Beer and friends help, too. Some wives are helpful, some are not, so that is a neutral issue.
