Old 01-31-2017, 08:22 PM   #1
rav007   rav007 is offline
sprocket problems!
Hey there, long time lurker first time poster! So it seems my hawk is a little, unique? maybe not and I've just not found the right thread. So I attempted to put on a 17-43 with an O ring chain and was met with utter failure. the 17 sprocket was causing the chain to grind on the INNER housing (engine side) so i dropped it down to a 16 and it was still grinding( pictures attached). I later realized the channel the locking plate goes into is on the inside instead of the outside? is this normal? took me a while to realize it, also having a big chain rubbing on tire issue, even with the 15-43, likely going to go back to 15-50 and see if i can use just the o-ring chain. anyone else seen this? see pictures, i reinstalled the 15 sprocket in the picture btw. thanks for your feedback!
also not sure if it makes any difference but this is the chain i got - 428HV - seems to be fine to me but I'm no chain expert! its 3mm thicker then the stock chain - measuring at 20.6 link end to link end, anyone know what the 428SO is measuring?
https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1
Old 02-01-2017, 08:11 AM   #2
So I slept on it and it struck me I can probably install the retainer first and slide the sprocket on, essentially reversing it and having the gear further out, not ideal but I'm thinking it will still hold on fine, thoughts?
Old 02-01-2017, 09:09 AM   #3
Sport Rider's Avatar
I went from a 15 to a 17 tooth using the stock chain. I had to grind off a tab on the inside of the cover for it to fit back properly. that may be part of your problem. kind of a dumb question, but the chain is the same size, right?
Old 02-01-2017, 10:49 AM   #4
Also, o-ring chains are substantially wider than a regular chain. I can't imagine there being issues with just swapping sprockets.
Old 02-01-2017, 11:14 AM   #5
It's an oring chain so it is wider. Only problem I see is that the tab I would have to grind off is the engine side, not the cover as I've seen with others. Not exactly sure what's on the other side! As far as chain as I understand it's correct and it fits the sprockets just fine, but being oring it is wider.
Old 02-01-2017, 11:14 AM   #6
Do you see the run mark on the left hand side on the engine cover? That's where it's hitting, not sure if grinding that are is a good idea?
Old 02-01-2017, 10:48 PM   #7
i had no problem with putting the 17 on mine. had to wiggle the cover a little to get it to go back on but it went. i kept the stock chain. shim or a fender washer behind the sprocket might move it out to clear the wider chain.
Old 02-02-2017, 08:43 AM   #8
I don't think you are seeing what I am referring to. Compare the sprocket location in this photo below to the one In my first post. Notice the one in my post the sprocket is to the inside and the one here is on the outside. I'm sure as new hawk owners purchase their 2016 bikes we will see more like this and a simple sprocket change isn't so simple anymore
Old 02-02-2017, 12:16 PM   #9
mtiberio   mtiberio is offline
mtiberio's Avatar
clearly the output shaft is different in the two photos you posted. The first picture shows the sprocket mounted much deeper on the shaft (or the shaft is longer). Someone probably makes a dished sprocket.
Old 02-03-2017, 08:40 AM   #10
wilserchinarider   wilserchinarider is offline
The different output shafts is puzzling. I think this is more of a chain problem than a sprocket problem?
From what I have read, an o-ring chain isn't really needed on these bikes???
Old 02-15-2017, 02:09 PM   #11
Bill1   Bill1 is offline
I just put new 17/45 sprockets on my hawk and a JT standard chain. My chain is rubbing slightly on the inside of the housing (engine side) like the original poster was talking about. My output shaft looks like the one in RAV007's first picture, with all of the shaft still showing.
Anyone have a solution?
I like the new gearing combo too much to switch back.
2016 RPS Hawk 250, exhaust, Uni Filter, Mikuni VM-26 clone w/ 120 main & 30 pilot, MSR shifter, 17/45 sprockets, JT chain, digital cluster...
Old 02-15-2017, 02:43 PM   #12
Ascot500   Ascot500 is offline
Has anyone looked at the chain's alignment?
If the two sprockets are on different planes, then the output shaft was likely mis-machined and this becomes a warranty issue.
But if the alignment is good, then the output shaft was likely revised to work with the rear wheel combo.
Old 02-15-2017, 02:52 PM   #13
Azhule   Azhule is offline
16t front 42t rear (2.63) should be a close enough ratio to the 17t front 45t rear (2.65) setup, the 16t should give you a little more clearance up front if that was your issue
Old 02-15-2017, 03:33 PM   #14
You can also go with a 40 tooth on rear and keep the stock 15 on front. Close to the same gear ratio.
2020 Kawasaki Vulcan S
Old 02-15-2017, 10:52 PM   #15
I rode the bike to work tonight, so I'll take the cover off again tomorrow and check to see how badly it scrubbed. There was some runout in the output shaft so hopefully it will not be as bad as I initially thought.
I will probably order a 16T sprocket anyway and maybe another rear in 42T.
