Old 05-20-2016, 11:08 PM   #1
slimjim503   slimjim503 is offline
Hawk forks
Hi everyone just got about 700 miles on the hawk and I changed my for oil had 150 ml in each tube. I noticed when I put the new oil in it sounds like it was still low when you pump the for tube it suck ing air sound so I put 200 ml in the I will let you guys no how it rides also the steering stem nuts where lose like finger tight so check them makes it kinda scary on gravel roads
Old 05-20-2016, 11:13 PM   #2
pcspecialist   pcspecialist is offline
Thanks for the info, Slim. I asked which oil and how much a while back and never got a response. Which oil did you use and do you think it is thick enough?
Old 05-20-2016, 11:27 PM   #3
I used belay 10 w fork oil you just need one bottle I'll let you no after I test it how it dose but 200 ml seems good
Old 05-21-2016, 09:48 AM   #4
traygiddens   traygiddens is offline
right , check that lower stem nut . mine was loose as well..
Old 05-21-2016, 05:02 PM   #5
Did you remove the forks, or, can you drain it out of the bottom. Last time I did forks it was in 1982 on a YZ125. Never had the need on any bike since then.
Old 05-21-2016, 07:55 PM   #6
I took them off and did it from the top and pump them just pull the spring and go at it
Old 05-21-2016, 08:17 PM   #7
I was hoping the procedure was different than with my YZ, guess not.
Old 05-22-2016, 02:08 AM   #8
mq1991   mq1991 is offline
If your just changing the oil, you dont need to.
-Undo the fork caps up by the triple tree
-Place a catch pan under the fork you are about to open
-Use a hex drive to remove the bolt at the bottom of the fork (Will be tight!)
-Let all the fluid drain into the pan
-Replace the hex bolt at the bottom of the fork and tighten
-Fill with (~150ml? I did 160ml and it seems to work great) of fork oil. I used this stuff
http://www.ebay.com/itm/231115859333...%3AMEBIDX%3AIT
1 bottle was enough to do both forks. I measured 150ml of water in a measuring cup, then poured that into a cheap plastic cup and made a mark where it filled to. I dried the cup and then filled to the same mark with the fork oil in the cheap plastic cup.
-Repeat on the other fork
Hope that helps! Post up any troubles you have along the way. Be sure to use the correct size hex key, if you strip that fastener it would be difficult to get it out.
Old 05-22-2016, 04:31 PM   #9
I thought that bolt on the bottom was good for something. Didn't have one on my YZ, or at least I don't remember one.
Oil is changed out and has enough now. What came out looked like motor oil. Feels like it should now.
Old 05-22-2016, 04:33 PM   #10
What size is the stem nut? I guestimate 30mm but want a socket on hand before I remove the handlebars to gain access to it.
Old 05-24-2016, 05:48 PM   #11
Johnp   Johnp is offline
Johnp's Avatar
Hmm. The listing was removed.
John P.
2016 Hawk 250 - Black
All my mods are documented on my Blog!
My Blog | Google+ | Twitter | Facebook
Old 05-24-2016, 05:50 PM   #12
Johnp's Avatar
So, a general question... How do you know if the fork oil needs to be changed? What are the symptoms, etc.?
John P.
Old 05-24-2016, 06:15 PM   #13
any 10w fork oil should do.
