Old 10-06-2015, 11:15 PM   #1
peperino   peperino is offline
Fuel tank capacity and float
Hey
As you may know, the bike tank capacity is not really the advertised, while every spec sheet you see will tell you that the bike has a 16L (4.2gallons) tank, in reality its capacity is 14L (3.7gallons).
Also, the fuel meter is not remotely accurate. In part this is for the way the fuel pump works, it needs to be soaked in fuel to avoid damage, so my guess is that Zongshen deliberately sets the indicator very pesimistic. That way you would refuel before you really need it and the tank would always have some fuel for the pump.
In my tests, when the fuel warning light blinks, you have only consumed about 7-8L (1.8-2.1 gallons) of fuel, so you have a lot of fuel remaining.
As my bike is carburated, no fuel pump involved, I decided to correct this indicator. To fix it, the idea is to take the tank off, remove the fuel float and bend it so it sits lower in the tank.
I think EFI users should also fix it so its not THAT pesimistic and a little more realistic, but just taking care of not draining the entiry tank when riding the bike.
I've made a step by step procedure, it is in spanish but you can easily google translate it (or ask me anything)
https://coltermoto.wordpress.com/tri...ible-flotante/
Old 10-06-2015, 11:40 PM   #2
If I had the carbureted version, I'd do the same thing. If I had the FI version, I'd leave it alone.
Old 10-06-2015, 11:41 PM   #3
Why.
Do you really think that the fuel pump needs THAT much fuel to work? We are talking half a tank here
Old 10-06-2015, 11:52 PM   #4
detours   detours is offline
detours's Avatar
Excellent write-up! I intend to try this at my next valve adjustment.
Red 5 standing by!
2015 CSC red RX3 with 19" front wheel, Shinko 804/805, skid plate, tall seat, 13T/45T sprockets, progressive shock, Winyoochanok windshield, GENSSI LED headlight, SW-Motech tankbag, Shorai Lithium battery
2014 Ural Patrol
Old 10-07-2015, 12:02 AM   #5
Feel free to grab the pictures and make a english step by step (or translate mine, whatever is easier for you)
Old 10-07-2015, 02:12 AM   #6
Why.
No, I don't think the pump needs that much fuel to function. I just think that more fuel for cooling is a good thing. I would simply get used to the range that is indicated by the gauge.
Old 10-07-2015, 10:23 AM   #7
I understand.
Unfortunately you would be losing a lot of mileage if you refuel as soon as the indicator blinks
Old 10-07-2015, 10:28 AM   #8
Thanks for posting a thread here on this excellent topic.
Old 10-07-2015, 10:35 AM   #9
Ok so, I refueled 3L (+ 2.5 that were already in the tank) and the light didn't blink but I also didn't have any bars in the indicator. So far so good, but I rode 10km and it started blinking again.
I think I'm gonna lower a little bit more so it blinks when you really are low on fuel, the idea is that it blinks when there's about 3L left, just about to hit reserve (reserve is about 2-2.5L.
Old 10-07-2015, 10:36 AM   #10
I'm thinking changing the float height to 30mm now
Old 10-07-2015, 12:14 PM   #11
keithmaine   keithmaine is offline
keithmaine's Avatar
Very good info.
2016 Versys 650 LT, 2015 RX3 Red, 2011 Ural GearUp,
Old 10-07-2015, 12:25 PM   #12
pepelepua   pepelepua is offline
pepelepua's Avatar
Great Job!
I supposed the problem was the gauge and my intention was to correct it with some resistors but you save me a lot of time with your post, the problem is totally mechanical !!!
Now you should see what happens in the full part of the gauge, maybe you´ll have a full indication until the middle of the tank, anycase, I prefer to have accuracy at the bottom part so I´ll do the mod soon.
So many thanks for posting.
Maybe we could meet sometime in Buenos Aires jaja!
Aguante la Ingeniería Argenta!
Pablo.
Today Riding a Corven Triax 250 Touring (Zongshen RX3)
Old 10-07-2015, 12:30 PM   #13
Originally Posted by pepelepua View Post
Great Job!
Yes, now comes the fine tuning, I need to find what float height works better for me
Old 10-07-2015, 02:15 PM   #14
rtking   rtking is offline
Thanks for the excellent tutorial. (I'll have to translate, but the photos were great and I see exactly what needs to be done.) Looking forward to the final recommended height of the arm.
FWIW, I usually don't rely on the fuel gauge and, instead, look into the tank before each ride, and I check how many miles I've put on the current tank through the odometer / trip meter. I find that the "manual" method is more accurate. I guess it's a non-issue anyway since the bike will easily cover 3 hours of riding on one fill-up, but I'm ready to stretch my legs (and/or pee) after 2 hours.
Old 10-07-2015, 02:17 PM   #15
Thats a very wise method keeping track your mileage, I also use it. My problem with the fuel gauge is that after consuming half a tank, I have a stupid light blinking at me for no real reason. That's basically why I wanted to fix it, not because I really needed the gauge
