Old 09-10-2015, 10:31 PM   #1
Hooligan   Hooligan is offline
TMEC issue i believe
Hey guys, having a slight issue with my TMEC 200. Ill be attaching photos of whats going on because ive no clue what the name of the part is.
There is a small metal tube on the right side of my cylinder that leads over to the left side to what looks similar to a mini carburetor, the original hose blew a hole in the side which caused the bike to sound much deeper and gives a crackle on the deceleration. But nothing else went wrong, all seems fine but i sure dont believe that tube would be there just for the heck of it.
So i went to a local hardware store, bought fuel line that was nice and thick and seemed good quality and replaced it, and barely a day later the same thing happened again.
Now i understand i probably just need better tubing that is more suited for such heat, but im really curious as to what that thing even does and if its worth my time. Any help would be greatly appreciated. thanks
Old 09-10-2015, 11:06 PM   #2
It is a kind of smog pump. I was wondering what it was, too, when I went with the new TMEC since my old '09 did not have it. I had the hole blow through, bought a fuel line, blew it, and then got a hot water hose from the auto parts store which has worked for several months now. One member a year or so ago simply found an aluminum plate and covered up the place where the exhaust originates from (and removed the pump altogether).
Old 09-11-2015, 01:55 AM   #3
so its not to imperitive of a piece and i can leave it for the time being? also do you know the thread that had the plate cover, sounds like something id be interesting in doing.
Old 09-11-2015, 12:04 PM   #4
IIRC, it's designed to provide a blast of air to assist the catalytic converter. I'd promptly remove it, but that would mean fabricating a block-off plate, removing the catalytic converter and perhaps even changing the main jet to something a little larger. A slight increase in power might result, because the cat is quite restrictive.
I performed that very surgery on a 50cc China scooter, but I haven't encountered a dual sport with that setup yet.
Old 09-11-2015, 02:08 PM   #5
bogieboy's Avatar
my roketa had all that stuff... removed the hose, welded shut the nipple on the head plate, and just recently cut the cat out of the exhaust.... bottom and midrange torque have noticably picked up since that....
Old 09-12-2015, 12:18 AM   #6
if anyone could provide maybe a few pictures on how to go about that and what exactly to do, id be very grateful. in the mean time im just going to deal with the small jet of exhaust blowing by my knees, and that beautiful crackle on decels. thanks for the info guys
Old 09-12-2015, 01:42 AM   #7
Why not hit the local auto parts store and get a hot water hose--mine's worked for several months now since the stock tubing blew out. I had to buy a foot of the tubing and it was under $2 for a foot of it from what I remember at O'Reilly's.
Old 09-12-2015, 01:45 AM   #8
I think this is the post I remember discussing blocking off the exhaust bypass (among several modifications to a TMEC)
http://chinariders.net/showthread.ph...highlight=tmec
Old 09-12-2015, 02:22 PM   #9
That's a helpful thread.
Old 09-18-2015, 01:52 AM   #10
Thanks a ton guys! ill be using that thread for future modifications as well
issue, tmec, tube
