07-28-2015, 12:30 PM | #16 |
Why is the wider rim harder to get tire off? I would of thought it gave more room to work the tire off once broke loose? rj
Live Zong, and Prosper Last edited by rjmorel; 07-28-2015 at 01:22 PM. |
07-28-2015, 01:09 PM | #17 | |
http://www.buchananspokes.com/catego...spoke_sets.asp
07-28-2015, 01:12 PM | #18 | |
07-28-2015, 01:18 PM | #19 | |
In addition, the wide rim also makes it more difficult initially to break the bead of the tire from the rim.
Spud "Never argue with an idiot. He will drag you down to his level, and beat you with experience." Mark Twain 2015 Zongshen ZS250GY-3 (RX3) 2006 Zongshen ZS200GY-2 (Sierra 200) 2005 Honda XR650L 2004 Honda CRF250X 1998 Kawasaki KDX220 Mods made to my Zongshen ZS200GY-2: http://www.chinariders.net/showthread.php?t=6894 Last edited by SpudRider; 07-29-2015 at 03:09 AM. |
07-29-2015, 12:13 AM | #20 |
That's a really nice rim, spud. Good job!
07-29-2015, 01:46 AM | #21 |
Thank you, Detours.
I went for a 110-mile ride today. After I returned, I examined the new wheel, and all the spokes were tight. Therefore, I am confident the wheel is sound, and I will check the spokes again the next time I remove the rear wheel. Here are a few photographs from today's ride, showing the new rear wheel from several different perspectives.
07-29-2015, 01:49 AM | #22 |
Here is a photograph showing how the size 5.10-17, Shinko 244 tire mounts very well to the narrower rim.
07-29-2015, 01:53 AM | #23 |
08-01-2015, 03:39 AM | #24 |
You did a fantastic job Spud. I recommend slime for punctures if you are not using already.
Zongshen 200gy-2 |
08-01-2015, 02:02 PM | #25 |
Thank you, Pliskin.
08-01-2015, 04:44 PM | #26 |
08-06-2015, 01:44 PM | #27 |
Spudly, Did you use the stock rear spokes on the Warp9 rear wheel build or did you need to have Buchannon make up the correct length spokes for you. Also....have you noticed any acceleration gains with the lighter rear wheel and tire. And......are your running a 13 or 14 tooth countershaft sprocket? Thanks for your feedback as always.
08-06-2015, 02:07 PM | #28 |
Yes, I used the stock rear spokes for the Warp9 rim. I only needed to purchase a 2.50-17 rim from eBay.
The rear wheel is much lighter, which makes it easier to change tires, and mount the wheel. The wheel will get even lighter when I switch to a size 4.60-17 tire. The bike handles great with the new rear wheel, and the unsprung weight of the wheel is much less. My butt dynamometer is pleased with the results, but I don't have any scientific data to corroborate an improvement in acceleration. I am running a 13T C/S sprocket, and it definitely has improved acceleration. I would love to test my RX3 versus a stock bike to note the difference in acceleration between the two.
01-18-2016, 05:05 PM | #29 |
Spud,
Have you removed a tire from your new aluminum rim? Was it "easy"? Easier than the steel rim? The reason I ask is that the aluminum rim looks like it has an extra rib a quarter inch or so inside the flange. I think I've read that the rib is for tubeless tires to hold them on better in low pressure situations.
Dan CSC RX3 Cyclone, CSC TT250, Moto Guzzi V7 II, KLR650 |
01-18-2016, 06:40 PM | #30 |
Spudrider, I'd like to rebuild my wheel, but I'm trying to decide whether to do it myself or have it done professionally.
Is it something a total noob can do? or should I get a pro to do it? I'm especially worried about warping the rim and screwing up the dishing.
