Old 10-03-2007, 12:41 AM   #1
SinnerDC2   SinnerDC2 is offline
Is there a smaller front sprocket? I think my stock is 14t
Is there a 12t or a 13t direct swap? maybe from a dirt bike?
Thanks,
Nick
Old 10-03-2007, 08:25 PM   #2
katoranger's Avatar
I think 14t may be about as small as they get. Possible a 13t.
Do you want lower gearing? You can replace the rear sprocket with a larger one too.
Allen
Old 10-04-2007, 12:49 AM   #3
correct, I want lower gearing. I want to see if I can do any wheelies on the bike. I'm figure gearing would be the best place to start besides the simple intake/exhaust and rejet mods.
Do you know where I can get a larger rear sprocket or smaller front sprocket?
Old 10-06-2007, 11:10 AM   #4
katoranger's Avatar
I have a stock 56t sprocket, but I don't know if it fits street bikes. I am not sure if the street bikes use the same style.
Allen
Old 10-07-2007, 12:31 AM   #5
ejcycles   ejcycles is offline
ejcycles's Avatar
The Sport bikes {200cc Street bike} doesn't use the same rear sprocket. The Grey Market Lifan Sport bikes do not, so if I'm not mistaken the American Lifan does not either. They might have 420, 428 or 520 chain on them and that needs to be known also. I have found this on different Lifan Sport bike models so it is imperative I know what chain you have and the measurements for the center hole and the bolts and how many bolts the rear sprocket has.
Thanks, Bruce @ Endless Journey Cycles
"Phone Calls Only" ~330-274-0098~
Hours: Tue.-Fri. 10:00-6:00 Sat. 10:00-4:00 EST.
Dealer for: Lifan, Crossrunner ATVs.
http://www.endlessjourneycycles.net
Old 10-07-2007, 11:59 PM   #6
mtliu   mtliu is offline
The LF200 sportbike most certainly does not have a 420 chain on it. A chain that size is generally (and for good reasons) not put on cycles of 200cc. Most likely, you have a 520 chain, but it could be a 428. The front sprocket interchangeable with certain Hondas and the rear is interchangeable with certain Yamaha models.
Old 10-08-2007, 05:17 PM   #7
How do I tell which chain I have?
Old 10-08-2007, 05:42 PM   #8
Phil_R   Phil_R is offline
Measure the (center to center) distance between any two adjacent pins... (one chain link)
4/8" = 1/2" = #428 chain
5/8" = #520 chain
Phil
'18 FXBB Softail Street Bob
'17 Tacoma TRD
