04-30-2015, 02:17 AM | #3226 |
I threaded the end of the handlebars with a 1/2-13 tap. The coarse threaded bolts are easier to find. Also, it is easier to install the 13 tpi bolt, since the bolt grabs the threads more easily. I used 1-inch long bolts, but I still have a lot of thread available inside the handlebars. Therefore, I am going to install either 1-1/2 inch, or 2-inch long bolts. This installation is very strong; I am pleased with the results.
04-30-2015, 02:36 AM | #3227 | |
How dose going to a smaller crank pin diameter increass the stroke ? Stoke is the centre line of the crank pin & main journal X2 the Dia of either has no bearing on the stoke.. to increass the stroke you have to move the centre line of them ferther apart...
04-30-2015, 02:58 AM | #3228 |
Don't you think it has to less liquid?
What about the oil level? I'm just regreting have bought this bike, the service center doesn't have a clue about this bike, I already take the bike to they, and they said it isn't anything wrong. I have 330 km riden. My first oil change, and they made me use syntetic oil, now I'm reading I shouldn't use syntetic for the first oil change. My guess is they haven't remove and change the oil filter and oil strainers. Is this gonna give me some trouble later, right? Any advice? |
04-30-2015, 03:52 AM | #3229 |
Wouldn't be worryed about syntetic oil.....
Yamaha recomends Yamalube which is Motul 5100 syntetic 10/40 rebranded for them.. .
09 XT660R ... 06 TTR250 ... 80 Montesa H6 125 Enduro... 77 Montesa Cota 348 MRR "Malcom Rathnell Replica"... Current resto projects.. 81 Honda CT110... 80 Kawasaki KL250A1... 11 Husaburg TE125 enduro... "sold" along with another 31... Lifan 125 Pitbike.. "stolen" ... KIWI BIKER FORUM...... http://www.kiwibiker.co.nz/forums/content.php All the best offroad rides in NZ... http://www.remotemoto.com/ E-mail... xtpete1@gmail.com Last edited by pete; 04-30-2015 at 04:37 AM. |
04-30-2015, 06:43 AM | #3230 |
Zong dash kit
i received my optionAl dash kit an was wondering. ,, while it looks pretty self explanatory , where does the relay go ?? Is it an addition or a just a heavier duty replacement for the existing one.And where is it located ? Thanks in advance
2015 zongshen rx3,,(Sold),,,2016 bashan storm,,2005 Harley ultra classic. |
04-30-2015, 08:27 AM | #3231 | |
So if you have a 24mm crank pin stock and switch to a 22mm pin. Keep the thickness of rod the same and the outside location of the pin the same the center line of the crank pin will move to a 2mm larger circle. Presto +2mm stroke. Now clearances to head must be maintained. So you need a -1mm rod length center to center. But the real clearance issue happens at BDC where now the piston is 2mm further towards the crank and case. This is why sometimes you see spacer plates put into stroker kits to clearance piston to crank issues. But then you run into cam timing and cam chain length issues. Other ways around it are pistons with different pin heights to compensate with using a crank and rod setup that has pin in higher location than stock.
Currently In the garage in various states of running (or not) order 2015 Rx-3 super speedy blue 2003 BMW F650GS 2001 H-D V-Rod 1999 Ducati 750SS 1997 Yamaha Riva 1995 KTM 250 1970 Honda CB350 1952 Ariel Square four |
04-30-2015, 09:15 AM | #3232 | |
This is my first oil change at 340 KM. Howvever I read on the CSC blog the first oil change should be not synthetic oil. Another question. In your bikes the oil is visible from the circular hole in the motor? even with the up mark. Please check my oil level in my photos in my other post. |
04-30-2015, 09:22 AM | #3233 | |
04-30-2015, 09:56 AM | #3234 |
What items are in the optional dash kit? Why does it include a relay?
04-30-2015, 10:21 AM | #3235 |
The relay is for the USB port, to drop the voltage to 5 volts (I suspect it is a transformer, instead of a relay)
04-30-2015, 10:24 AM | #3236 |
Thanks, Huck.
04-30-2015, 10:28 AM | #3237 |
This was just my assumption...I have nothing to back that up....but would need something to drop the voltage....and the Lighter plug works without the "relay" plugged in, so it has to be for the USB plug
04-30-2015, 10:40 AM | #3238 | |
http://item.taobao.com/item.htm?spm=...ucket=4#detail
04-30-2015, 11:26 AM | #3239 | |
I look forward to seeing your installation thread, though I fear this might be a bit much for me to tackle with no other experience under my belt at least I have something to aspire to |
04-30-2015, 11:33 AM | #3240 |
Yesterday I went for a ride to test my suspension settings and handguards. Here are a few photos from that ride.
I believe I have optimized my suspension with the Mobil1 Synthetic ATF in the forks, and the shock rebound damping set at the #10 position. The handguards are strong, and well positioned. All controls worked well.
