Old 03-10-2015, 11:47 PM   #1
TheGammaGhost   TheGammaGhost is offline
Question Roketa DB-06 no lights!
Hey guys, been a long time!!
I went to start my bike the other day, via kickstart, and once i had it running, i noticed i have no lights at all, no indicators, headlights tail lights, nothing! i tried trickle charging my battery and i still have no lights or anything, i checked the one fuse that i know of and it looked okay, so maybe it has more than one, and it could be blown, i have the wiring diagram, but i cant really tell whats a fuse on it, and its not labeled, if anyone has any suggestions or wants to check out the diagram its here...
http://www.scooterdynasty.com/manual...s%20Manual.pdf
any help is greatly appreciated!
-thegammaghost
2021 Boom Vader Gen 2 BD125-10 Current
2011 DRZ400S Current
2006 LIFANIZED ROKETA DB-06 200cc Sold
2008 Ninja 250R Sold
1984 Honda aero 125 Sold
1980 Honda CM400T Sold
Old 03-11-2015, 10:17 AM   #2
You're likely to have only one fuse, and if the electric start works, the fuse is probably intact. Nevertheless, it's a good idea to check the fuse with a meter to be sure.
If it is not the fuse, I'd look to the ignition switch. It has four wires, and one of them might have some off. That happened to me.
Old 03-11-2015, 10:38 AM   #3
humanbeing's Avatar
Most vertical chonda is similar to
Old 03-11-2015, 11:06 AM   #4
Adjuster's Avatar
Does your bike have a rectifier?
Old 03-11-2015, 10:28 PM   #5
Thanks for the help, wierdly enough when I got home from work and tried it, the lights just all worked, not really sure what the issue was. Hope fully it stays good, thanks again!
Tgg
Old 03-12-2015, 09:56 AM   #6
I both love and hate problems that fix themselves. I hope it remains fixed for you.
Old 03-15-2015, 03:58 AM   #7
Trailbikeryder   Trailbikeryder is offline
Trailbikeryder's Avatar
This seems like the same problem I'm currently having.
http://www.chinariders.net/showthread.php?t=14495
@ TheGammaGhost
did you ride in wet conditions before is happened?
My CB : http://www.youtube.com/watch?v=ZbZ8q-grmOQ
2012 Skyteam V-Raptor 250
2011 Yamaha Tenere XT 660Z abs
1996 Kawasaki Vulcan 800 Classic
1989 Kawasaki GPZ 500
db-06 rhm-200ed 200cc
