Thread Tools Display Modes
Old 01-23-2015, 08:38 PM   #76
There is still engine braking, but you can't ease into it by revving the motor to match the wheel speed. I can live with that.
Old 01-23-2015, 09:38 PM   #77
recracer   recracer is offline
recracer's Avatar
http://moboshi.en.alibaba.com/produc...rom_China.html it appears in this setup that the centrifugal clutch is mounted to the crankshaft and retains the normal clutch basket
Old 01-24-2015, 01:24 AM   #78
Interesting. I wonder what the price is.
Old 01-24-2015, 05:22 PM   #79
recracer's Avatar
I will find out . I did get a nice sales girl ,Named June to speak to me on this site . She was being as helpful as she could . I am sure she never was Questioned about retro-fitting automatic clutch before . 2 concerns I have about this one . Case clearance and what happens to the oil that goes to the centrifugal filter .
Old 01-25-2015, 09:40 AM   #80
recracer's Avatar
picture from Dan's motorcycles repair
Old 01-25-2015, 01:44 PM   #81
I watched a Youtube video on old Honda ATC centrifugal clutches as well, and they looked just the image you found at Dan's. I'm beginning to think that an old ATC engine is the best move. I could always combine the transmission with a CG230 motor.
Old 01-25-2015, 02:52 PM   #82
Brother Dan posts a lot of good information.
http://www.dansmc.com/mc_repaircourse.htm
Old 01-25-2015, 11:38 PM   #83
recracer's Avatar
Seems a retro-fit makes no sense . I watched the you tube videos and see the manual clutch gets actuated by the shifter on a gear change . IE no help for your dad . We would still need our clutch lever or change to much , for it to be reasonable. Whole automatic engine seems a better way to go. That being said ,for the rest of us . We would still be able to revved clutch drops and roll to a stop without holding the clutch in .
Old 01-26-2015, 01:47 AM   #84
I've ridden a Honda Big Red, and there was no clutch lever. It was a true semi-auto with a five speed transmission and a centrifugal clutch. If I could find one, it would meet his needs.
Old 01-26-2015, 01:47 AM   #85
A semi-auto would also be an excellent teaching tool for new riders.
Old 01-26-2015, 02:08 AM   #86
Adjuster's Avatar
My original motor for my bike is a 49cc 4 speed semi auto. It does in fact have a lever activated clutch but its built into the foot shift lever. When you apply slight pressure to the shift lever it activates the clutch, then as you apply more pressure it shifts the gears.
Old 01-26-2015, 02:22 AM   #87
That's the same setup as the small horizontal Hondas, and I believe the ATC's are also like that.
Old 01-26-2015, 09:09 AM   #88
recracer's Avatar
That is what I meant to convey , It would be difficult for us to employ gearshift clutch action , in a retrofit to our engines .
Old 01-26-2015, 12:44 PM   #89
katoranger's Avatar
Will be on the lookout for a big red motor. I see lots of those old ATC around here.
Old 01-26-2015, 01:27 PM   #90
That is exactly what I thought you meant. Thanks for the vid.
