10-29-2014, 09:31 PM | #1 |
Any support for a maxfine?
I've got this mxf150-4n with large bits of wire harness missing
My google-fu is failing me for diagrams, manuals etc. |
10-29-2014, 09:44 PM | #2 |
The bore is 61 OR 62 mm? Those parts are CHEAP in taobao.com.
http://item.taobao.com/item.htm?id=5209316229 Split diagram for typical "vertical":
10-29-2014, 10:41 PM | #3 |
Well that's more than I found.
Any way to translate? |
10-29-2014, 11:27 PM | #4 |
10-30-2014, 12:27 AM | #5 |
I recommend that you use Google Chrome to view the page, and allow it to translate automatically. Not perfect, but usually workable.
10-30-2014, 01:12 AM | #6 |
I'll try that. Thanks.
10-30-2014, 01:36 AM | #7 |
Those 61mm OHC are related to GL145.
http://www.motorfans.com.cn/bbs/view...originator=yes Loncin CBD150 isn't that bad http://www.miniriders.com/tech-talk/...-engine-3.html --- Stock headlight is as GL145 http://item.taobao.com/item.htm?id=37270298771 GS125 "pig head" http://item.taobao.com/item.htm?id=9744681913 can jammed in. http://www.motorfans.com.cn/bbs/t_17731036.htm Stock instrument is as some Suzi. http://item.taobao.com/item.htm?id=35757249141
11-01-2014, 12:40 PM | #8 |
Thanks for the info thus far.
The google chrome translation is ........ Amusing. But may still be of use. Ima try to get after this a bit today. |
11-01-2014, 12:45 PM | #9 |
And I gotta say.... The 21/19 wheel size seriously surprised me.
11-01-2014, 02:08 PM | #10 |
For all it is worth, see if a TMEC 200 parts catalog shows that bike using a similar diagram:
http://www.atv4usa.com/catalogs/TMEC200-1.pdf (page 19 and 20)
"They say that life's a carousel, spinning fast you got to ride it well..." TGB Delivery Scooter 150 TMEC 200 Enduro--carcass is sadly rotting in the backyard Last edited by culcune; 11-01-2014 at 03:49 PM. |
11-01-2014, 04:16 PM | #11 |
Well I got it running ( needs carb work and exhaust leak fixed)
I gotta find something to do with the ignition lock. I have no key. Lol |
11-02-2014, 04:36 AM | #12 |
replacement lock? or toggle switch? if i am not wrong you ll need two toggle switches, one for the light circuit and one for the ignition. you could mount it somewhere hidden and won t need no key again. keep the ignition barrel mounted as a decoy.
looks like a fairly new bike.
1971 Garelli Gulp 50cc with open ports and 16 mm Bing Carbie + 1980 Honda XL 223 ZS + 2007 Zongshen LZX200G + DR400SM |
11-02-2014, 11:12 AM | #13 |
This ignition switch is weird.
I can't tell what the pictograms on the switch are supposed to mean. It has two wires with continuity "on?" And 2 with continuity "off?" And the lock/fork lock position has no contacts. I also can't read the secondary light switch. The wiring diagram posted doesn't match wire colors so I'm a little confused there. |
11-02-2014, 11:14 AM | #14 | |
Edit: 193.6 miles. Speedo cable is ripped off. Tach cable is ripped off. On the positive side, I got the kill switches and ignition switch parts of the engine side done. Now for rectifier lights and gauges.. Last edited by Rix86; 11-02-2014 at 04:48 PM. |
11-02-2014, 08:51 PM | #15 |
Most wiring diagram shows Honda color coding BUT that bike maybe a "hybrid" (the insurment is Suzi style)
Color doesn't mean ANYthing in used (PO may hacked it) / off brand (Maker may use whatever on hand) , trace w/ test lamp , multimeter for exact meaning. http://www.dansmc.com/electricaltesting.htm --- Suzi http://do.ejdz.cn:8087/%E6%91%A9%E6%...3%E5%9B%BE.gif http://do.ejdz.cn:8087/%E6%91%A9%E6%...3%E5%9B%BE.gif Yammie: http://do.ejdz.cn:8087/%E6%91%A9%E6%...3%E5%9B%BE.gif --- Most chinese odo reads in km (times 5/8 is the approx mile reading).
