08-03-2014, 04:30 AM | #16 | |
Qualified sparky in China always stocks these color http://item.taobao.com/item.htm?id=15260137841 | http://item.taobao.com/item.htm?id=36602654320 I "borrowed" the whole color collection from my contractor uncle when doing improvement project in the ancestral house. ***second great grandpa was in OZ during gold rush & made some fortune to built it. --- off topic: In theory , it's as national standard BUT many are wired as "old" British in my home county. http://en.wikipedia.org/wiki/Three-p...er#Color_codes ---
08-03-2014, 04:05 PM | #17 | |
My CRF250X had a lighting coil for an AC headlight, but I converted my CRF250X to a pure DC system using a Trail Tech stator and regulator/rectifier. http://www.rockymountainatvmc.com/p/...0tech%20stator The CRF250X has an AC-CDI unit. The DC-CDI units for the Honda XR650L are notorious for failure. These CDI units become noticeably hot during operation. The solder joints on the printed circuit board of this DC-CDI deteriorate, and fail. Most people suspect the thermal cycling of the internal transformer is responsible for the ruined solder joints.
08-03-2014, 04:17 PM | #18 |
Interesting.
My Lifan will run the headlight with the engine off, but my TW will not, nor will my old TS Suzukis.
08-03-2014, 04:26 PM | #19 | |
What model year is your TW200? It must have a lighting coil. If so, you will convert your TW200 to a pure DC system if you install the Zongshen stator. The Zongshen system will generate more power to charge your battery, and will give you a nice, steady headlight at all rpms. However, you will probably need to install a larger regulator/rectifier. I suggest you get the unit employed by my Zongshen 200GY-2. You will also need to connect your headlight to a keyed power line which is connected to the battery.
08-03-2014, 04:37 PM | #20 |
All three of my old TS Suzukis are factory dual sport bikes, so they're all equipped with batteries.
My TW is a '93, and it was built before the introduction of the more powerful stator. I might upgrade eventually. If I do, I'll change to all Zong.
08-03-2014, 04:41 PM | #21 | ||
08-03-2014, 04:48 PM | #22 | |
08-10-2014, 09:26 AM | #23 | |
=== Chinese: DJ7081Y-2.3-21 http://item.taobao.com/item.htm?id=39109777167 Furukawa https://www.furukawa.co.jp/tukuru/pd...pcon_01rfw.pdf ===
08-10-2014, 12:19 PM | #24 |
Indeed, that appears to be the correct connector! Thank you, HumanBeing.
03-26-2018, 05:11 PM | #25 |
Zongshen wiring harness
Anyone have any clue where i'd be able to get a proper wiring harness for the 2006 zongshen ZS200GY desert fox. i've looked everywhere but it seems like the only part i cant find.
03-27-2018, 10:41 AM | #26 |
Welcome! Thanks for joining us. I recommend Taobao, since I've purchased several parts there for the ZS200GY, although not for a few years.
09-13-2019, 08:20 PM | #28 |
Do you know if the CDI units are still available from Taobao? I looked at their website and entered the part number in the search box but didnt find anything. Anyone in the US selling these units? I have a 2006 200 GY tht has a failed cdi unit.
09-13-2019, 08:32 PM | #29 |
I might be able to help but I am a seller etc.
09-14-2019, 06:17 AM | #30 | |
[Hints] Item #: 39214124554 [交流CDI] / Agent: sup**buy / shipping method: EUB (known as ePacket in proper English)
