Old 08-17-2011, 07:39 PM   #1
midlifekrisiz   midlifekrisiz is offline
zongshen 250 clutch
i have fried the clutch on my zongshen.
Need input as to where to get parts other than e-bay (nothing on there anyway)
I could be wrong......it has been known to happen<div><br /></div><div>core directive 172: No member of the core shall report for duty wearing a ginger toupee</div>
Old 08-17-2011, 09:30 PM   #2
There's plenty on eBay. Here's a decent price, and you can have it shipped to Sumas to save some cash; that's what I do: Clutch Assembly
I had a quick look on the Gio site, but they don't seem to stock any right now. The only local shop I can think of is Saga.
Old 08-17-2011, 11:06 PM   #3
ya that's the right assy but I would think that I can rebuild it no?
the oil definitely did not smell right and even a friend said fried clutch smell
there were also lots of small bits of crud in there
also will I have to make my own gasket for this casing? (not like it is a problem)
Old 08-18-2011, 01:18 AM   #4
Sure you can rebuild it, but the entire assembly is likely a better value. You can get a replacement gasket or use a product like Three Bond or Loctite flange sealant.
This is a good time to point to the round cover to the right of the clutch, with three retaining screws and a spring in the middle. That's the cover for the oil pump pickup, and it's likely full of junk. Carefully remove the cover, and then dig out the sludge before putting things back together.
Old 08-18-2011, 01:21 PM   #5
just waiting for a call back from that fellow in abbotsford off of craigs list....he advertises that he carries clutches and parts so see what he can do first. Weld...you might want this guys #.
Old 08-18-2011, 01:53 PM   #6
wooohoooo he has the plates and they are $5.00 each. pick them up tomorrow.
Old 08-18-2011, 05:31 PM   #7
went out and took the clutch apart and cleaned everything.
reverse is on the left and the smooth one on the right is first...well there's your problem. :roll:
here is what was left behind after filtering the varsol through a rag
Old 08-19-2011, 01:09 AM   #8
Was there sludge behind the oil pump pickup cover?
Old 08-19-2011, 01:52 AM   #9
there was some caked on stuff in there around the edges of the cover and then the rest spread around here and there.
Old 08-19-2011, 02:34 AM   #10
TCCKSR   TCCKSR is offline
TCCKSR's Avatar
another reason to crack the engine once a year, give it a good cleaning, change a few worn parts and toss it back together.
Its not like these are all that hard to rebuild too.
I am going to make that part of my normal routine now. So I have to keep a spare set of gaskets, and a few other parts around, that might cost me a whole $50??
TCCK: The Coca-Cola Kid......... Hide your pepsi or I take your soul !!
Old 08-19-2011, 07:23 PM   #11
picked up the parts and gasket today ...... $40.00 total.
plates are soaking in oil now.
Old 08-19-2011, 08:23 PM   #12
next question ....i have 5 disks and 4 spacers . do they go 4 in the long slots and 1 in the short slots or 3 in the long slots and 2 in the short slots?
from my pic (should have taken a better one) looks like 3 in long and 2 in short.
Old 08-19-2011, 10:33 PM   #13
called the guy i bought them from and he says all in the same long slot.
going together tomorrow.
Old 08-20-2011, 06:54 PM   #14
all back together and working better than ever.
after that was done and a few test rides down the alley....went on to fix a break in the plastics.
drill the holes
cut some mechanics wire
bend into stitches
insert and twist from behind
thats enuff for today.... going riding tomorrow.
Old 08-24-2011, 03:10 AM   #15
northerndad   northerndad is offline
This is awesome, thanks for posting the pics. I'm guessing I'll be doing this kind of thing to my Beast in the near future...
