04-08-2007, 05:39 PM | #16 | |
Re: GY-5 front winkers
Here is what I did... Others here have done the same. Gonna do the rear ones soon.
http://www.chinariders.net/modules.p...532&highlight= Quote:
The destination is merely a by-product of the journey. '06 KLR650 '06 XT225 '92 XT225 Serow ( MBD.... Multiple Bike Disease...) |
04-08-2007, 06:06 PM | #17 |
I had to change the way the choke was mounted on the left side.
The right side was not a problem. Looks better than it was
2006 Lifan LF200GY-5 |
04-08-2007, 06:26 PM | #18 |
Looks good, I think they should work good there
04-08-2007, 07:32 PM | #19 |
here is the rear
06 american lifan 200 gy-5 |
04-10-2007, 12:03 AM | #20 |
they also have hand guards with winkers built in if you want a cleaner look but i wanted the front to match the rear
04-10-2007, 12:15 AM | #21 |
jeffhei, yeah I just noticed today my dads choke is mounted the other way around aswell.
04-11-2007, 04:00 AM | #23 |
Savage
Auction; http://cgi.ebay.com/ebaymotors/ws/eB...romZR40QQfviZ1 Sure they will work, you just have to watch the watts for the bulb. Changing the bulb wattage will change how the turn signals operate {slower or faster} depending if the wattage is higher or lower. You may have to change the bulbs in the turn signals you purchase or the flasher relay. I hope this helps. Bruce
Thanks, Bruce @ Endless Journey Cycles "Phone Calls Only" ~330-274-0098~ Hours: Tue.-Fri. 10:00-6:00 Sat. 10:00-4:00 EST. Dealer for: Lifan, Crossrunner ATVs. http://www.endlessjourneycycles.net |
04-12-2007, 10:25 PM | #24 |
Helps, but opens another question. :wink:
What watts work for our "winkers"? What's the safe range? Kinda off topic, but not too bad: I think the headlamp is 35W, how much brighter one can I put in there and still be OK? Thanks all! |
04-13-2007, 09:30 AM | #25 |
It's not what's a safe range, it has to do with what you buy and what watt bulb is in the ones you buy. All of the aftermarket lights on the market {all of them} have a certain wattage/candlepower bulb in them because the bulb is so close to the plastic lens. To high of a wattage bulb in a lot of these will melt the plastic. The higher the wattage/candlepower the hotter the bulb itself gets. You can put a higher wattage/candlepower bulb in some because the plastic cover is further away from the bulb, but be careful. You may also have to change the flasher relay due to this also. There are no books that have recommendations on this you just have to figure it out for yourself, as I do.
Bruce
04-13-2007, 09:43 AM | #26 | |
Jason
2008 Jonway MC-70-150 2007 Roketa DB-07B (RSM-200E) 2006 Roketa DB-07A (RSX-200E) 1995 Kawasaki Concours (ZG1000) |
